Introduction: Can Cast Concrete Pencil Holder
What inspired me?
Well, I love obscure, weird and impractical materials such as concrete while incorporating the material into a project where its features, properties and function isn't required. I love concrete as its such an industrial material and has a very smooth finish.
What will you need?
- Empty cola or pop can.
- Tin opener
- Concrete (cement sand and water)
- Three jars, one for sand, water and cement.
- something to mix with
- Very narrow tube or can
Step 1: Making the Mould
Step one - Making the mould
This is the part that you can change. Find any sized can and then using a sharp pair off tin openers, begin to cut off the top of the can. Depending on the type of tin opener, it will be either very easy or very hard.
When the top is off, place the can under warm water to clean the insides, but be careful the edges will be very sharp and if you place your fingers inside you will cut them!
Wait for the can to dry then move onto the next step.
Step 2: Mixing the Concrete
Step Two - Mixing the concrete
Depending on what materials you have depends on this step. You can get all sorts of colours, finishes, tones and types of concrete. Snow-Crete looks great as its white tone is modern but rustic. I used plain cement, sand and concrete. But you can get ready mixed concrete which is much better.
Empty about one cup of cement into a bucket. Empty one cup of sand into the same bucket and then mix until you get a nice grey coloured mixture. When you are happy with the colour, add one cup of water. Mix well until you get a smooth thick liquid. If you don't think it looks as thick as in the pictures, add more sand or cement mix.
You can add different chemicals to the paint such as pain, stones, glass or dyes. This enhances the dull grey colour of your concrete.
Because you are making a pencil pot, why not use sharpen from the pencils after they have been sharpened and mix these with the concrete. Or even chop up a pencil or two and stir in with the concrete mix.
Step 3: Pouring the Mix
Step three - pouring the mix
The difficulty of Pouring the concrete depends on what you are pouring the concrete mix into. If the container/mould is small and narrow, it will be difficult. If the container/mould is large then pouring will be an easy process.
When the concrete has been mixed and you're happy with the overall consistency, you are ready to pour. Place the bucket close if not over your mould, using your mixing tool, begin to push a bit of the mix In to the mould. Only add about 2cm then tap the mould onto the table to ensure the bottom us covered completely. Begin to add more until your mould is 3/4 full.
Insert the tube, ensuring it has a bottom, into the mould making sure it doesn't hit the bottom.
Bang the mould onto the work surface softly until the top surface becomes smooth and flat. Feel free to add your own touch here. You can make it smooth, rough, uneven or tapered.
Step 4: Waiting for the Concrete to Set
Step four - Waiting for the Concrete to set
When you have finished pouring the concrete into the mould and you are happy with the positioning of the insert, then just sit back and wait for the concrete to set. Depending on the amount of water you added, the time taken for the concrete to set will either be between 2-24hours. But if you put a lot of water in the mix, your concrete will be very soft, and may even crumble. Wait a day and check to see if the concrete has set.
Step 5: Finished!!!!
Finished!!!!
When the concrete has set, take the mould off. You can do this by either using scissors and cutting the metal can. When the mould is off, use a small brush to get rid of any unwanted concrete.
Well-done! you have done it! You have made your every own Concrete Pencil Holder
You can really have fun with this, change the size, shape and depth of the can and the colour or type of concrete.
Anyway, thank you for reading and I hope you liked it! Please favourite and follow my account. Ill be adding different projects every week. Comment below if you have an idea for me to try, a feature I can improve it just to tell me what you think. Thank you!
Makerspace Contest
Maker Olympics Contest 2016
