Candle Holders That Hold Candles Steady While Re-Purposing Scrap Materials
Intro: Candle Holders That Hold Candles Steady While Re-Purposing Scrap Materials
Most candle holders I have obtained don't fit the candle very well. They are too wide and shallow or two thin.
One ought just be able to drop a candle in and have the candle remain straight and steady.
So I desgined a candle holder to do just that from re-purposed materials.
It will take less than 15 minutes, even if one is slow
STEP 1: Materials
Materials:
Hot Melt Glue
discarded CD
Approximately 15 cm of 1 inch /2.5cm white PVC pipe, preferably used from a remodel or scrap.
A few inches of foli ( Optional)
Paint ( highly optional)
Tools:
Hack saw for cutting PVC pipe
( Or pipe cutting tool )
Miter box, (not required, but highly recommended )
Rasp or file
Hot Melt Glue Gun , plugged in and starting to melt the glue.
Hot Melt Glue
discarded CD
Tools:
Rasp or file
STEP 2: Optional Step: Paint or Sand the Pipe
If you want the pipe a color other than white or foil covered, it may help to paint it now.
Or at least sand off any printing that may be oin the pipe.
STEP 3: Cut a 4 Cm Piece of PVC Pipe
Cut a 4 cm( 1.5 inch) piece of the pipe.
Use asaw and miter box or a pipe cutter
Make the cut square or the candle will tilt..
(Before starting the cut, make sure that the glue gun is plugged in so there is no waiting for the gun to heat up)
After cutting, check the cut to make sure it is square.
Use the rasp or file to file away the bur and to make the cut square if it is not already so,.
Put away the remaining piece of pipe for another day.
The reason a 15 cm piece was listed was to make it easy to handle the pipe
STEP 4: Apply Hot Melt Glue to CD
If the glue is not already melted, then plug the gun in and wait.
Place the CD shiny side up
When the glue is melted, apply a circle of the glue around the center of the CD.
The bead should be about a1 cm thick around the center of the CD
Be generous with the glue.
Be quick to go to the next step.
STEP 5: Push the Pipe Into the Hot Melt Glue
As soon as the bead of glue is on the CD,
Push the end of the 4 cm piec of pipe into the glue.
Hold steady till glue hardens, about a minute.
Then add a bead of glue around the base of the pipe.
STEP 6: You Are Pretty Much Done,
But keep reading anyway
Rub off any extra glue from the CD
STEP 7: Decorate As You Wish
At this point, you can wrap foil around the pipe
Or you can spray paint everything.
STEP 8: Caution: a Candle Flame Could Smolder the PVC Pipe
If the candle flame gets close to the pipe, bad fumes could be emitted .
If the pipe and candle are wrapped in foil, that risk is is lessened.
In any case, replace the candle before the top of the candle reaches the top of the pipe.
Here is what the trade site says about pvc and flame:
Fire retarding properties of PVC pipe
PVC is an inherently fire resistant plastic, the only exception among the general-purpose plastics, since it contains more than 50% of chlorine.
When PVC products are burned, hydrogen chloride gas resulting from thermal cracking slows down the continuous combustion reaction and prevents burning progress by warding off the PVC product surface from oxygen in the air. The gas is also detectable by its – highly unpleasant - odour at concentrations well below those that could be harmful to health. This feature allows early detection of a fire.
From : http://www.pvc.org/en/p/fire-retardant-properties
STEP 9: Instead of a Discarded CD, You Could Use:
A saucer
An upturned cup or bowl
The lidf of a can
Almost anything
You could use several pieces of pipe and attach them to a single base for a more elaborate piece.
The lidf of a can
Almost anything
STEP 10: Instead of Hot Melt Glue
Instead of Hot Melt Glue you could use :
Some other glue, like epoxy
Maybe silicon sealant
Maybe model cement
Ask your local Ace Hardware or Craftwood Lumber guy
The value of hoyt melt is that there is no curing or drying time.
STEP 11: Alternative Solution for a Candle Holder
Here I made a disk of epoxy putty and stuck the pipe in.
Not pretty, but funcional
Epoxy is expensive unless it is on clearance sale.
2 Comments
Wilmette 11 years ago
Also tried "Instant Grap" construction adhesive. That did not work.
Epoxy always works
dreiseratops 11 years ago
Dig it.
Stars AND or Eebies to you.
