Canning Lid Labels @ TechShop Chandler
Intro: Canning Lid Labels @ TechShop Chandler
This is a tutorial for some laser cut labels for canning jars. I've recently started canning my own tomato sauces, and I wanted to have a label that wouldn't require adhesive. These labels are made to fit the standard size lids, not the wide mouth lides. These instructions are assuming that you are using the Universal Lasers @ TechShop Chandler, and that you have taken the SBU and are familiar with how to operate the machine.
For more information on the TechShop or to schedule a class, visit techshop.ws.
STEP 1: Gather Materials
For this project, you will need the Illustrator file provided, painter's tape, and cardstock paper.
STEP 2: Customize File & Print
Open up the Illustrator file and change the text to whatever you would like. You can make the text smaller or change the font if you would like. Just make sure that whatever you want to be etched on the coaster is in black.
When you have finished customizing the look of the labels, go ahead and print from Illustrator to the laser program. From the print screen in Illustrator, make sure to hit "Setup" and "Preferences" to access the laser settings. Set your material height to .01", and choose Construction Paper for the material. Make sure to hit apply. Access the Manual settings tab, and change the black settings to a power of 20%. Once you are back in the print dialog, hit "Print"
STEP 3: Setup Material on Laser Bed
Place the cardstock on the laser bed, and use the painter's tape to hold down the edges. If the edges aren't held down, then the exhaust air will blow the paper around when the lid is closed.
STEP 4: Print to Laser
Once in the Laser Control Panel, use the "Focus View" option to move the laser head to the spot on the material that you want to start cutting at. Then use the "Relocate" option to move the image to where the pointer is positioned. To do this, select the grab point on the image that you want to line up with the start point, and then hit "To Pointer" in the bottom right hand corner of the screen.
Once you have the start point lined up, you can use the "Duplicate View" option to print more than one label at a time. In this example we will be printing 6 labels by setting both the X to 3 & Y to 2.
When you have completed all these steps, you are ready to start the file printing. Go ahead and press the big, green Play button.
STEP 5: Label the Jars
Once you have processed your jars, and they have had time to cool, take off the lid band. Place the label in the top of the band and screw it back onto the jar.
Enjoy!
2 Comments
gowlery 10 years ago
wilgubeast 10 years ago
That is beautiful and well-explained overkill. Try naming this with "mason jar lids" and see if it spikes your views (your URL won't change, so experiment as much as you want.)
