Captain America Halloween Costume
Intro: Captain America Halloween Costume
True Believers! You know that America needs a real hero, and next year for Halloween, you, too, can be that hero! With just a few easy steps, you can become Captain America and impress your family, friends, neighbors, and local Legion members. (Our Cap ended up saying the pledge at the local legion as part of a scavenger hunt, and it went over extremely well.) Be a hit at conventions and use it to demonstrate your patriotism to young and old alike.
Let's get you on your way to your service as a super soldier, citizen!
STEP 1: Materials
You will need the following:
A white long-sleeved athletic shirt
If no vertically-striped shirt can be found, red fabric (preferably with the same amount of stretchines as the shirt) (not pictured here)
A blue athletic t-shirt
Blue running tights (or sweatpants if suitable ones can be found) (not pictured here)
Red vinyl (we ended up using about 2 1/2 yards or so) (not pictured here)
Blue vinyl (about 2 yards total) (not pictured here)
White vinyl (about 1/2 yard) (not pictured here)
Blue fabric (if you choose to make the cowl out of fabric)
Wide black belt (not pictured here)
Red gloves (we used fleece ones, but anything red would be good) (not pictured here)
Stitch witchery
White thread
Tape measure
Rotary cutter and/or scissors
Heavy-duty blue thread
Super glue
Tons of pins, both safety and straight
A small quantity of stuffing (not pictured here)
Velcro (not pictured)
Red duct tape (not pictured)
Blue duct tape (not pictured)
Stitch witchery
White thread
Tape measure
Super glue
STEP 2: Making the Undershirt
Because we couldn't find a shirt with vertical red stripes, we had to make one. If you can find one, skip this step!
First, measure your subject and shirt. Divide that number by 12 (we figured Cap should have 13 stripes like the flag...but that made two stripes of the same color end up next to each other, and that definitely didn't work). I ended up cutting my strips at about 3". I cut the red first, then cut the bottom of the shirt off and cut white strips.
*This is where I would like to make sure that you're aware of the difficulties of trying to sew together two fabrics of vastly different stretchiness. Don't do it! I basically just ended up stretching the white as far as it would go and had to pin down both ends fully extended in order to pin the red to it. It worked, and we were pretty happy with the results, but I wouldn't recommend it. I am including my pictures, however, to help out anyone who, like me, couldn't find suitable red fabric.*
Then pin and sew your strips to one another, then back to the bottom of the shirt.
STEP 3: The Cowl
Or hood...or helmet...or whatever you want to call it! In our first draft, we made the cowl out of the extra t-shirt we bought. After mis-placing the eye- and ear-holes, we scrapped it and went with the vinyl, which was difficult to sew, but I think it was a better-looking choice in the end.
Our cowl consisted of a long rectangle for the middle and two side pieces that started in a semi-circle then transitioned into flaps that cover the neck. I can't really give much more exact instructions, and I'll let the pattern pieces speak for themselves. Measurements will vary according to the head size of your model.
Once the pieces are cut, pinned, and sewn, (carefully) cut the eye- and ear-holes. Carefully check your sizes and spacing. Cut the "A" out of white vinyl and superglue it to the cowl. I cut the little wings out of white vinyl and sewed them inside out by hand then turned them right side out and stuffed them with poly filling. I sewed them to the hood as well.
We used velcro inside the cowl to keep the flaps together.
STEP 4: The Gloves
First, cut vinyl to serve as gauntlets. Use red duct tape to attach it to the gloves. Tape around the edges for stability. Be careful to leave a big enough slit to allow for getting the gloves on and off. Cap also wrapped tape around the fingers for a more even shiny red look.
STEP 5: Boots
Of course, this would have been easier with red boots, but without, Cap wrapped his shoes in red vinyl and attached it all together with red duct tape. He then made cuffs out of red vinyl and the pattern for that is pictured.
STEP 6: The Armor
Here comes the tough part...the armor!
First, cut the bottom off the blue t-shirt. Then, use the stitch witchery to fuse the middle of the star to the shirt. You'll want the points of the stars to be loose so that you can sew scales under them. The star pattern came from www.elegantmusings.com. When printed with Windows as a fax print, it's just about the perfect size and shape.
Then cut scales. Cap estimates that he and his friend Dan cut about 200 scales total. They are around 2" x 2". After the scales were cut, Cap creased each of them down the middle with an iron to prevent them from curling.
We then painstakingly pinned each scale down and sewed them on in rows. I had the best luck on my machine with the tension turned all the way up, but it really could have gone higher because I kept having tension issues. Once the scales were all sewed on, the tips of the star were glued down and then we sewed a long piece of vinyl around the neck and pinned the back down with safety pins.
STEP 7: The Whole Shebang
First, put on your pants. Cap recommends long underwear underneath. Then put on the boots, then the pants. Follow those by the striped undershirt and the armor, then the cowl and the gloves last.
Our Cap didn't make his own shield; he got it on E-Bay, but there's a great instructable for how to make your own Captain American shield.
Wear it with pride, Citizen, and make your country proud!
20 Comments
jeditanker72 8 years ago
Great Job!
avenger22 9 years ago
This is a great idea. I'm going to use a lot of your methods this Halloween.
CrystalB01 10 years ago
shirrel 12 years ago
Fruppi 12 years ago
aazana 12 years ago
Fruppi 12 years ago
aazana 12 years ago
egriff 15 years ago
Hoaxinmi 14 years ago
ToshiroMifune 15 years ago
Fruppi 15 years ago
WurdBendur 15 years ago
Fruppi 15 years ago
smithn 15 years ago
Fruppi 15 years ago
animed 15 years ago
mg0930mg 15 years ago
Weissensteinburg 15 years ago
