Car Body Leak Repair
78,446
15
18
Introduction: Car Body Leak Repair
December might not be the best time of the year to discover that there is water inside your car, especially when you live upstate New York... and your car is staying on an open air parking lot!
I waited for a snowless day, with temperature above freezing to venture taking a look at the problem. Water was accumulating under the front passenger seat, under the rug, threatening to turn the car into a mobile swamp. To find a leak, your only option is to spray every corner of the car with water and patiently observe and listen where the dripping comes from. It turned out that the water was coming from the trunk.
Under the rug in the trunk, both the spare wheel and the jack compartments were completely underwater. Driving the car was enough to jiggle the water under the back seat. Water would accumulate under the passerger front seat, due to gravity.
Step 1: Drying and Testing
Since the water, was entirely on the passenger side, the leak had to be on that side too. I started by drying all the water inside the trunks. I had to take the rugs, the spare wheel and the jack out of the car. I needed something to scoop the the water out and had an empty bottle of shampoo with the top cut, slim enough to get the water stuck inside narrow compartments. I got as much water as I could like that and finished drying things with an old bath towel. Once everything is dry, it's much easier to see where water comes from!
The procedure is to spray the, beforehand closed (!!), trunk with the water from the pitcher. Get someone in the car, the back seat pulled down, with a flashlight to listen and watch where the water comes from (I managed to both spraying and spying). The picture shows what I saw: the water was coming from the backlight!
Step 2: The Demon of Duct Tape
On my car, it's fairly easy to take the back light out (3 nuts to unscrew) and a nice and easy pull got it out. You ought to know how to do that if you ever want to change a broken lightbulb! The light taken out, it was easy to see where the problem was. Now, how to seal the leak?
The first thing that came to my mind was, of course, to use duct tape. It sort of worked, but not so well... Indeed, it is difficult to make a perfect seal with duct tape on a surface with acute angles, so I went for something a little more sophisticated: tub and tile adhesive caulk! I found that stuff (that looks like a big toothpaste tube) at my local hardware store for less than 5 bucks. I rubbed the opening with the the caulk and smoothed it with a popsicle stick.
You're supposed to let the caulk dry from a couple of hours to a day (depending on what you bought). Because my car is parked on an open air parking lot, I couldn't leave things like that. I therefore reassembled the backlight, and to insure that things would stay dry, I duct taped it to prevent the water from getting onto the caulk.
Step 3: It's All Good
Luckily for me, that night it didn't rain. Before putting the car to the test, I had to see if the caulk had dried the way it should (despite the somewhat low temperature). It looked pretty good to me (c.f. picture) and ready to take a shot. I therefore repeated the spraying and spying procedure, this time with abundant quantities of water. It's been a couple weeks already, with rain and snow: I'm happy to say the repair is a success!
Stay dry,
Le Gazier.
Be the First to Share
    • One Board Contest
      One Board Contest
    • Knitting and Crochet Speed Challenge
    • Jewelry Challenge
      Jewelry Challenge
    18 Comments
    AsheeqahA
    AsheeqahA
    5 years ago
    HI, I need urgent help.
    It has been raining like crazy by us, and when I got in my car this morning, I discovered a huge puddle at the back seat. The water went up till the drivers seat. I am unsure how to fix this problem, and it will be raining hole week here. I can not deal with a wet floor and the damp smell it will give off.
    Please let me know what is the best solution before I spend R1000s to fix the problem.
    legazier
    legazier
    Reply 5 years ago
    Sounds like you want to get your car under a roof, get as much water as you can out of it and then let it dry some more.
    ElizabethE24
    ElizabethE24
    5 years ago
    How long does it take to diagnos and repair carvwater leak? I have an idea where the water was leaking when I brought in to the dealership. Its more than 2 weeks now, the service advisor keeps dragging on. Any advice, thanks.
    legazier
    legazier
    Reply 5 years ago
    I am not a car mechanic, and so I cannot speak for your dealership. I can tell you that for this specific case, it took me a couple of hours to do what I described in this instructable, and a full night for the caulk to cure in place.
    I do hope you'll soon hear back from your mechanic. Two weeks do sound like they must be super busy.
    LisaB187
    LisaB187
    5 years ago
    97 Toyota Camry has same problem. Possibly related to the dashboard "headlight" warning light remaining on? All lights work, thought it was a bad sensor. Now I think it's due to the loose molded plastic cover plates for the tail lights in the trunk...?
    LeonS21
    LeonS21
    6 years ago
    I can't believe it!!!!! You've done it..... Found my leak that is:) this has been haunting me for so long. I didn't know where to start and after months of research i still didn't know where to start. WOW!!! I've still got my MAZDA 323 and those pics are identical to mines. The water is literally travelling all the way to my rear right passenger footwell. Dude i can't thank you enough for the write up and those incredible pics... Thanks a million Dude you just saved my trusted buggy.I was so frustrated i was just about to sell O.M.G. Thank you so much...
    legazier
    legazier
    Reply 6 years ago
    Well, thanks for this amazingly positive feedback. I posted this eight years ago, and haven't thought much about it, but right now, I just feel like a million bucks ;-) May you keep your 'trusted buggy' many more years!
    97 GRAND AM-DRIVERS FLOOR BOARDS LEAK IN FRONT & BACK FLOOR BOARDS????
    WHEN IT RAINS MY DRIVERS SIDE FRONT & BACK FLOOR BOARD IS SOAKEN WET AS IT HAS AN AWEFUL LEAK "some where" & I HAVE CHRONIC ILLNESSES & AM NOT SUPOSE TO BE AROUND THE MELDEW, I'VE LEFT MY WINDOWS CRACKED TO HELP SOME, BUT LEARNED THAT ABIT TO LATE, GRRRR AT ME.... I'M ON LOW INCOME & I'M ON A FIXED INCOME & SO TrYiNg TO FIGURE OUT AWAY TO MAKE ALL FALL INTO PLACE IS IMPOSSIBLE & IS SO DEEPLY NEEDED... CAN YOU "PLEASE" HELP GUIDE ME WITH ANY SUGGESTIONS/HELP PLEASE? APPRECIATE YOUR TIME & UNDERSTANDING... ANYONE ELSE HAVE A GRAND AM"BRIGHTEST BLESSINGS ALWAYS"...
    91Cavalier
    91Cavalier
    9 years ago on Introduction
    Any suggestions on a 91 Chevy Cavalier? There always seems to be water buildup behind the drivers seat. As far as I've seen going through the exterior body, "no obvious indicators" which would lead someone to believe there would be a leak on the inside. Any assistance would be great! Thanks in advance.
    mole1
    mole1
    10 years ago on Introduction
    Thank you!! I've never understood HOW one was supposed to look for leaks before.
    I used a shop vac to get water out of the trunk of our '90 Camry today. I have no idea where the water is coming from, but if it isn't freezing or raining tomorrow, I hope to try your method. (Aren't those wells supposed to drain somehow?)
    [Just in case anyone else has a similar problem... we had enough water to float a piece of 2x4 on the driver's side of an '85 Tercel for years. I used the bathtub stuff everywhere I could think of. It turned out that the flimsy sheet of plastic (lack thereof) inside the front door was the problem. It didn't look important, and it got torn up when fixing the window after a break in. ]
    cmorgan45
    cmorgan45
    11 years ago on Step 3
     im experiencing the same exact problem with my 2003 mazda protege es and im so grateful i found this. i just applied the caulk to my car and im currently waiting on it to set-up i was wondering how well this actually worked for you and if you currently have any problems with this also does your car leak on the passenger side floor board in the front? if so please tell me what you did to fix that.
    legazier
    legazier
    Reply 11 years ago on Step 3
    What a surprise, to read feedback more than two years after this instructable was first posted! This one leak was responsible for all the water I had in the car. The fix proposed here with the caulk actually worked out pretty well: two years later, I am still driving the same car, and have never found any water anywhere in the car... so give that a shot and let us know how that works for you.
    Cheers!
    cmorgan45
    cmorgan45
    Reply 11 years ago on Introduction
     thanks so much ive tried this out and im still curently waiting on it to fully cure but so far its dry and the car has gotten wet so im guessing its fixed. thanks for posting this i kinda got lucky you have the excat car i do and the exact same problem so it was easy to find and fix. im beginning to think that that defect is a major design flaw in mazda's part because ive seen alot of forums on this exact problem for the protege.
    Solderguy
    Solderguy
    13 years ago on Introduction
    The gel won't stop the rusting if it managed to get past the car paint. The best way to get rid of it is to buy a can of spray the same color as your car interior paint, scrape the rusted paint off, and apply the can of paint in thin layers on afflicted areas.
    hondagofast
    hondagofast
    14 years ago on Introduction
    The trunk of my car looks like that... I have no idea where the leaks are...
    natnie
    natnie
    Cool. My sister's car gets puddles in the front seats and we have no idea where it's coming from. We'll try this method out! Thanks!
    Patrik
    Patrik
    Great detective work, and some nice pictures!
