Introduction: Card Throwing - the Simple "trick" to Do This Right
I saw a couple of card throwing instructables on here which where very good, but after spending a long time following the instructions I was getting nowhere.
After some practice I figured out the simple piece that was missing. You should not try to throw the cards but spin them!
Step 1: Getting Started.
All you need to get started is a deck of cards and somewhere to throw them. I would suggest somewhere indoors where you won't knock stuff over and break it.
Any cards will do, I used cheap crappy paper ones and expensive plastic coated ones and didn't notice a lot of difference.
The main things to keep in mind are:
*Don't try to throw the card! This sounds silly but this is exactly the mistake I was making. The card has no weight and if you try and throw it like you would a heavier object it will flutter for a bit and land about 2ft away. You need to spin the card and this action all comes from the wrist. The faster you can spin the card the better it will fly!
*You will have to put some forward motion into your forearm but this should be a gentle, relaxed motion just to give the card some forward momentum.
*You need to keep your wrist and arm very relaxed. The whole motion does not require a lot of force and you will probably find that the harder you try and throw the card the less likely you are to succeed.
The next page shows the two ways I held the card.
Step 2: How to Hold the Card.
I found two ways to hold the cards (see the pictures below). Both worked for me but you might find one works better then the other for you.
The first way was to hold it in-between your index and middle finger at a slight diagonal with the tips of your figures on the corner of the card. When you throw it you want the card to pivot around the tips of your figures to give it a spinning motion.
The second way is actually very close to the way I hold cards when I'm dealing. Hold the card in the middle with your thumb and middle finger and have the tip of your index finger on the corner of the card. As you throw it you use your index finger to add the spin.
Step 3: Throwing Technique.
As I mentioned the whole aim is to have a relaxed, smooth, arm movement to give the card forward momentum and a relaxed snapping of the wrist to give the card spin. You hardly have to move your forarm at all. The picture below shows you the movement that you want.
Remember! Do this gently, trust me it will work much better this way then trying to put lots of weight behind it.
Once you get the technique down (which if I have explained this properly should be on about the 2nd or 3rd card you throw) you can get good distance on every single card.
The more you practice the faster you will be able to spin the cards and the further and faster you will be able to get them to fly.
27 Comments
12 years ago on Introduction
at first it can be very hard to master this but over time u will be suprised at what u can do. i threw a credit card 275 feet.............. so............ work hard and that could be u
Reply 7 years ago
Hate to ruin this but the world record for card throwing is 216 ft 4 in. You didn't beat it or everyone would know you. Also, there would you've thrown it?
Reply 6 years ago
but the world record was with a standard playing card rather than with a credit card.
A credit card weighs in at a little over 12 grams, and a playing card comes in at around 1.7.
I think it's pretty easy to believe someone could throw a credit card that far.
6 years ago
Check out this video of a very easy playing card shooter build. It is very fun!
https://www.youtube.com/watch?v=4B_dIVdfJh8
7 years ago
Hey guys! I watched this card throwing tutorial and it really helped me out! defiantly recommend it.
https://www.youtube.com/watch?v=Ssp3B3Z5wA4
7 years ago
Wow! This is a very helpful tutorial! You explained so well in great detail on card throwing. Now I want to read more of your tutorials. Thanks a lot!
Cardistry Tricks
7 years ago
Thanks man u are really awesome thanks for the wonderfull technique
7 years ago
Oh my god, this was so helpful. I practiced a lot with no results and than right when I read about the second grip I was throwing it really well! Thank you!
9 years ago
Thanks bro this helped.
9 years ago
Nice instructions my friend really helpful
9 years ago
AMAZING THIS IS AWESOME
Haha... i don't use this technique (even though this is a good one) and i can through cards at my brother and they give him big welts, and sometimes they even make him bleed. :)
Reply 11 years ago on Introduction
... umm....
is he, you know, okay with this?
Reply 12 years ago on Introduction
nice! :D
Better cards don't make too big of a difference, but you will notice a vast change in speed and form if you compare a deck of flimsy paper cards to something like a credit card or room card. They go faster, farther, and hit harder. Not that that last part matters quite as much...
I found a better wrist technique http://howtohacklife101.blogspot.com/2011/05/how-to-throw-playing-card.html
Wow this helped alot, thanks
13 years ago on Introduction
wow thanks man
14 years ago on Introduction
also, as an add on to this, do not throw cards at PEOPLE. it sounds fun....but really, can do extreme damage to some one (if you throw it right). It will bruise, puncture, and slice someones body. on youtube there is a video of someone throwing it into a watermelon skin...(big deal i can throw it into a tree trunk) <-- thats how dangerous it is. by the way it will go in about 3 inches deep into a tree.
Reply 14 years ago on Introduction
I am one of several people who has a video on youtube of card throwing into watermelons. But on the topic of the above comment, there are few trees I can take a sharp axe to, and bury it 3 inches in, much less a card. The exaggeration that i see across the web, exemplified in the above comment, makes me irritated. If you have nothing truthful to say, please, don't comment on something.
