At this moment I have seen the trick, not the revilation
I believe the card has a duplicate, I saw you do a riffle force to get the right card, and I assume the girl's in on it
The cloth has a pocket holding the duplicate and you switch the ripped card for the original one.
now let's see if I'm right...
whow, it's even easier then I thought, though I think a pocked would have helped
also, I didn't see the moves because it's a bad trick (It's quite good actually) it's because I use the same techniques for other tricks
10 Discussions
8 years ago on Introduction
Video does not show!
11 years ago on Introduction
I don't get it.. I thought the trick was about the "same" card WITH the writing on it....
How do you go about THAT?
Nicely done.
i did not understand, i thought you put the card with the name on the rope. it would be nice if you added voice.
12 years ago on Introduction
its a begginer trick
i saw that trick from a mile away
At this moment I have seen the trick, not the revilation I believe the card has a duplicate, I saw you do a riffle force to get the right card, and I assume the girl's in on it The cloth has a pocket holding the duplicate and you switch the ripped card for the original one. now let's see if I'm right... whow, it's even easier then I thought, though I think a pocked would have helped also, I didn't see the moves because it's a bad trick (It's quite good actually) it's because I use the same techniques for other tricks
Clever routine, relying on a stooge, however, it is entertaining and can be very mystifying to those not it the know.
13 years ago on Introduction
this is pretty cool i guess.
Would you mind uploading a screencap of your video to this instructable to act as a thumbnail?
