Cardboard Breakfast-In-Bed Tray
Intro: Cardboard Breakfast-In-Bed Tray
Cardboard Breakfast-in-Bed Tray
Mother's Day, Birthday or another special day has arrived and you want to provide that special someone with Breakfast in Bed!
BUT you don't have a good way to serve it.
IMPROVISE!
Make a Breakfast-in-Bed Serving Tray out of Cardboard!
STEP 1: Cut Off Bottom of Box
Cut the "tray" out of the bottom (or side depending on the shape) of the box. You want to make your cut about 2 inches up from the surface you are using for your tray, usually the bottom.
This two inch distance is the wall height of the tray. You can adjust it for higher or lower tray walls.
STEP 2: Cut Holes for Legs
Mark the locations of the legs by tracing around a cardboard tube. When locating the tube you need to leave some space between the tube and the edge of the cardboard for the thicknesses of the tray wall.
You can see in the last photo I had to adjust my placement to get enough space to the wall.
You could mark and cut the hole from inside of the tray but the upturned walls make it more difficult.
Mark and cut the leg holes in each of the four corners.
STEP 3: Add Legs
Push each of the cardboard tube legs through the holes you have just cut.
Hot glue them into place. Especially gluing them to the upturned walls of the tray so that the legs have rigidity.
STEP 4: Cover Open Tops of Tubes
If you like you can cut out circles of decorative paper to cover the openings of the leg tubes.
STEP 5: Reinforce the Tray
A single sheet of cardboard is not what you want holding all the trappings of a nice breakfast. Think of milk and orange juice spilling all over the bed! So it is wise to strengthen the tray.
I did this by adding two sheets of flat cardboard over the surface of the tray. Ideally it should completely cover the tray, but the pieces I had were slightly smaller. I added them anyway, and there was only a small gap.
The extra cardboard sheets greatly improved the strength of the tray and there was no sagging under the weight of breakfast!
STEP 6: Enjoy Breakfast in Bed!
Your Breakfast-In-Bed Tray is complete.
Surprise that special someone with Breakfas-in-Bed!
Enjoy!
