Introduction: Cardboard Faux Fireplace
It's beginning to look a lot like Christmas, especially now that my apartment has a fireplace!
All you need is a large cardboard box, a box cutter, scissors, tape, , hot glue, brown wrapping paper, and a Sharpie.
Step 1: Tape Up the Corners of a Large Cardboard Box.
I used duct tape to secure the corners of a large cardboard box so that it would stand up on its flaps.
Step 2: Cut Out a Rectangle to Leave Space for the "fire."
Use a box cutter to cut out a rectangle from one side of the box. I found it easiest to do so on carpeted floor (it didn't hurt the carpet). To give you an idea of the proportions, my rectangle is seven inches out from the edges.
Step 3: Cut the Box in Half.
Since the box is quite large, and I wanted my mantel to only stick out about a foot form the wall, I used the box cutter to cut the box in half, using the flaps as a guide.
Step 4: Make Extensions to Your Box If Necessary.
Depending on how big your box was to begin with, you may want to make it taller or wider to get it to a good fireplace size. On my box, I cut off the flaps on the half I didn't use and hot-glued them to the bottoms of my fireplace, overlapping by a couple inches. This brought the total height up to four feet. Since it was now so tall, I decided to widen it as well by cutting the horizontal piece in half and inserting another piece of cardboard. This insert was reinforced with more tape and another cardboard piece underneath.
Step 5: Decorate Your Fireplace!
I cut out brown wrapping paper (~$6 at Staples, but I barely used a fraction of the roll) and wrapped the front of the fireplace. I wrapped the middle horizontal piece first, then the sides, and finally the extensions at the bottom. All of it was taped down with brown paper tape. I tried to trim the inside corners to get a mitered corner look.
I looked up Art Nouveau designs and used pencil to sketch my "carvings" onto my fireplace, then traced over it in Sharpie. This website also has a lot of line art examples of different fireplace looks, some of which are easier to reproduce than others:
http://www.stevensons-of-norwich.co.uk/products/paginate_by/all/
Step 6: Set Up Your Fireplace.
I placed my fireplace on a wall so that one of the vertical pieces covered up a socket. That way I could set up my lights for the "fire" in the middle and then plug it in and have the plug be hidden.
My fire is a string of Christmas lights looped around an upturned ceramic bowl with a pillar candle in the middle, all set up on a box that I draped with some fabric. I put more fabric on the top of the fireplace and set up Christmas cards and other lightweight decorations. For extra support, I placed a couple of pushpins in the wall under the horizontal piece.
1 Person Made This Project!
- ScottS103 made it!
9 Discussions
6 years ago on Step 6
This is cool, i am going to make one to surround my space heater mini fireplace, to make it look full size. Plenty of room to breath in there and i have fireproof base material to put heater on
8 years ago on Introduction
This is wonderful! It goes so well with your decor'. I would keep it up all year round. Thanks for a great instructable!
You need to paint it. Even if you were to go with a "natural" wood look, you'd need to paint it. Just what every apartment needs...for the fake fire, I'd go with Goldie's Bubbling Cauldron instructable.
I was going for a quick and easy holiday decoration for our apartment, not a real wood look. The drawing was enough for me, although if someone wanted the wood look they could certainly paint it. Thanks for pointing me toward the cauldron; for Christmas I like the lights, but I'll keep the cauldron in mind should I ever need such a thing.
No prob. I've used it before and the effect is quite nice especially in a low light setting.
9 years ago on Introduction
Really Nice!!! :)
Now I need a cardboard fire place.
Beautiful! Definitely intend to do this when I move!!!!!!
The footings are a nice touch, I'll bet you could finish this with textured paint job and it would look almost authentic. Also, kitty seems to approve, that's always a good sign!
