Introduction: Cardboard Flounder Fun
This costume idea originated in a school project. We were challenged to design a marine related costume using only slotted construction and recycled cardboard. We were not allowed to use any type of adhesive that could prevent the ability for the costume to separate and store easily. As the project progressed, new ideas were formed, and eventually, the final product came to be.
Design Brief
In order to promote the "being green" concept, build a costume using recycled cardboard. Use slotted construction and no fasteners or adhesives to give the costume the ability to store flat and easy.
Specifications
- use recycled cardboard to build costume
- use slotted construction to assemble the costume
Limits
- cardboard only
- no fasteners or adhesive
- slotted construction to assemble parts
Step 1: Material List
Item Material Description Quantity Size Remarks - Part
S1 Cardboard Sheet 1 7 feet x 6 feet You may use more than one sheet if u can't find one this big. Make sure the sheets are big enough, however.
Item Tool Use
T1 Cutting Mat Protect surface on which the cardboard is cut.
T2 Utility Knife Cut the cardboard into pieces.
T3 Ruler Measure pieces and cut straight lines.
T4 Pencil Draw template on cardboard for where to cut.
T5 Circle Template or Compass Assist in cutting well-measured circles or ovals.
Step 2: Part 1 (P1): Cardboard Fish Body
Step 1. Use the ruler (T3) and pencil (T4) to draw an oval 3 feet long and 2 feet wide on the cardboard sheet (S1).
Step 2. Use the utility knife (T2) to cut on the penciled in lines on the cardboard sheet (S1).
Step 3. Use the utility knife (T2) to cut a slot 1/4 inch by 3 inches out of the bottom of the cardboard sheet (S1).
Step 4. Use the compass (T5) to draw a circle with a 6 inch diameter offset to the top of the cardboard sheet (S1).
Step 5. Use the utility knife (T2) to cut the circle out of the cardboard sheet (S1).
Step 6. Repeat steps 1 through 5 to make two complete cardboard fish bodies (P1).
Step 3: Part 2 (P2): Cardboard Fish Tail
Step 2. Use the pencil (T4) and ruler (T3) to connect the ends of the half-circle.
Step 3. Use the utility knife (T2) to cut out the cardboard fish tail (P2).
Step 4. Use the utility knife (T2) to cut a 1/4 inch by 3 inch slot in the center on the straight side of the cardboard fish tail (P2).
Step 4: Part 3 (P3): Cardboard Connector
Step 2. Use the utility knife (T2) to cut the cardboard connector (P3) out of the cardboard sheet (S1).
Step 3. Use the utility knife (T2) to cut three 1/4 inch by 3 inch slot in the cardboard connector (P3). Cut one slot in the middle on the bottom and the other two slots 2 feet apart on the opposite side.
Step 5: Parts List
P1 2 Cardboard Fish Body
P2 1 Cardboard Fish Tail
P3 1 Cardboard Connector
Step 6: Assembling the Costume
Step 2. Insert the slot on each cardboard fish body (P1) into the two slots on the top of the cardboard connector (P3).
