Cardboard Hand Saw Blade Guard
Intro: Cardboard Hand Saw Blade Guard
Ever accidentally grab the blade of a saw when reaching to grab it off the pegboard and accidentally grasp too hard?
Blade guards can be essential in the above case to ensure that you do not cut your hand. However, they can be unnecessarily expensive (a quick Google search returned http://bit.ly/1bHZThw which goes for a whopping 5 bucks...).
This is a very simple guide to make your own blade guard using everyday household materials (or at least easy to obtain).
STEP 1: Stuff Needed to Build It and Make It Happen
I used the following to make this blade guard:
~Materials
-Cardboard (cereal box works well)
-Hand Saw
~Tools
-Scissor
-Stapler
Other ideas to make this include using twist ties, rubber bands, slit straws, etc. I chose this idea for its simpleness.
~Materials
-Hand Saw
~Tools
-Scissor
-Stapler
STEP 2: Cutting & Fitting
I started of finding a scrap piece of thin cardboard from the cache.
A cereal box or cardboard of the same thickness works well.
Test fitted the piece to ensure that once folded over, it would cover the blade.
Cut, crease halfway, and trim of excess if desired.
Test fit.
Test fit.
STEP 3: Stapling & Fitting
Start from the end furthest from the handle and move your way towards the handle. Test fit as you go to ensure best fit.
STEP 4:
There are many ways to hand your saw, these are two different ways but I personally prefer the latter.
To make the hole, determine where the saw hole will end up once inside the guard, and use scissor point to poke a hole and enlarge if necessary.
STEP 5: Finale
Thank you for viewing this Instructable.
Happy DIYing!
Happy DIYing!
3 Comments
GreenBlindness 6 years ago
Gonna make it and glue a cut to size jean leg on the outside for the aestetic appeal and to cover up the staple marks.
artworker 10 years ago
jamesabt007 10 years ago
