Carduino- a Simple Arduino Robotics Platform With Its Own Library
Intro: Carduino- a Simple Arduino Robotics Platform With Its Own Library
This is, as the title says, an Arduino-based robotics platform, with its own library. The "standard" model comes with two back motors, two omni-wheels in the front, and a distance sensor mounted on the front. It also has breadboard space on top for adding whatever you want. It is intended to be autonomous, but one can make it remote controlled if they really want to. This instructable will teach how to build it, how to use the library, and it will include some sample projects too.
What is the library?
The library will make controlling your Carduino a little easier. This project is intended for those with little programming experience, and just want to get started with simple robotics. You don't even need to know how to use a motor shield to use it. It's as simple as saying "turn right for 1 second" or "go forward for 3 seconds, and then speed up." The library also contains example code to help you get started.
What exactly is in the library?
Step 13 contains all the important information regarding the library, and all example projects.
Why would you ever want a wooden chassis, and is it fine if I build mine differently?
Of course you can build yours differently! The library will work almost no matter what you do, so you can change the design to whatever you'd like. The only reason why I used a wooden chassis was because it was the only material for this I had, so you can feel free to use whatever else you'd like.
What can this robot do?
It can do just about anything. Even just with the parts on the standard model, there is infinite possibilities. With Arduino and the Carduino library, programming it is incredibly easy, and it can do anything you can imagine. The extra breadboard space allows you to add a variety of sensors, to make it do just what you want.
How much does it cost?
Roughly one hundred dollars, if you're starting out with nothing. I had almost all the parts before I started, so the price was only about thirty dollars for me. Most all of the parts are very common, and you should have many of them.
Here is a terrible video of it in action:
(due to some issues with the distance sensor, I could not get object-avoidance in the video, but, I assure you, it works)
STEP 1: Supplies
1 Arduino Uno http://www.sparkfun.com/products/11021
1 Breadboard http://www.sparkfun.com/products/9567
1 Arduino and breadboard holder http://www.sparkfun.com/products/10059
1 Sharp long range proximity sensor http://www.sparkfun.com/products/8958
2 Micro metal gear motors http://www.sparkfun.com/products/8910
1 Pair of 49x19mm wheels http://www.sparkfun.com/products/8899
1 Pair of motor mounting brackets http://www.sparkfun.com/products/8896
1 Pair of omni-wheels http://www.sparkfun.com/products/320
1 Arduino motor shield http://www.amazon.com/gp/product/B007BHKRVW/ref=oh_details_o00_s00_i00
1 15x10.75cm piece of wood (check size with the Arduino and breadboard holder)
12 #4 x 3/4" Wood screws
1 9v battery
Some Wire
1 9v battery
Some Wire
STEP 2: Set Up Various Things
Here some things you need to do before you begin:
Cut wood to correct size
Make Omni-wheels (instructions came with them)
Attach wheels to motors
Insert Arduino and breadboard into the holder.
STEP 3: Mount Omni-wheels
Position both of them 0.5" from the front, and 0.5" from either side. Mark holes for mounting, then drill them. Use your #4 x 3/4" wood screws to mount them.
STEP 4: Mount Motors
This step is fairly easy. All you do is insert the motors into the mounting brackets, and super glue the brackets onto the corners. You may want to have already solder wires to them though, I ended up needing to remove the motors to solder later on.
STEP 5: Mount Arduino & Breadboard
You should begin by centering the Arduino and breadboard holder on the chassis. Remember that the breadboard should be in the front. Next, mark holes to drill. Then Arduino and breadboard holder already has to holes in the center, you should use those. After you marked the holes, you need to drill them, and mount the holder using #4 x 3/4" wood screws.
STEP 6: Mount Proximity Sensor
This should be fairly straightforward. Just mark holes, and drill. You should be using the mounting holes on either side of the sensor. It doesn't need to be centered on the front, but if you want it to be, it should be about 1.5" from either side. Use #4 x 3/4" wood screws, yet again. MAKE SURE that when you do this the JST is on top.
Insert your JST wires into the sensor.
Now, put the red wire in the positive thingy in your breadboard, the black wire in the negative, and the yellow can go anywhere in the breadboard.
STEP 7: Attach Motor Shield
You should know how to do this, just line it up and stack it onto your Arduino.
STEP 8: Solder to Motors
Just solder some wires to you motors. Make sure to remember which are positive, and which are negative.
STEP 9: Wire Motors to Motor Shield
This is much more complicated than you would imagine.
Wire positive on the right motor to the negative terminal for motor A.
Wire negative on the right motor to the positive terminal for motor A.
Wire positive on the left motor to the positive terminal for motor B.
Wire negative on the left motor to the negative terminal for motor B.
If anyone believes these are wrong, please notify me. I am quite sure that I'm correct, but there is a chance that I lost track of which wire is which.
STEP 10: Wire Breadboard and Sensor
Connect 5v to the positive column thingy in the breadboard. Connect GND to the negative thingy. Connect the yellow sensor thing to analog pin 2.
STEP 11: Attach Battery
Just super glue a 9v battery to the back of your Carduino. Then, attach the positive and negative wires (either soldered or with battery clip) to the positive and negative terminals on your Carduino.
STEP 12: You're Done Building!
You have finished building the "standard" model of the Carduino. The great thing about the Carduino is any Carduino can run any Carduino code. All of the examples that come with the library will run on your Carduino, without any modifications. Next, I will explain the library, and exactly what's included.
STEP 13: The Library
To install the library:
Download Carduino.zip at the bottom of the step. Find /arduino-1.0/libraries. Extract the library to that location. Now, to use it, open up the Arduino IDE, go to sketch -> import library -> Carduino.
Here are the functions in the library:
void mycarduino.begin ()
Starts up the Carduino. Call in setup ().
void mycarduino.goforward(float seconds, int speed)
This function moves the Carduino forward for the specified time and speed. The speed should be any number from 1 to 1023, with 1023 being the fastest.
void mycarduino.goback(float seconds, int speed)
The same as the function above, only backward.
void mycarduino.turnright(int time)
Turns the Carduino right for the specified time, in milliseconds.
void mycarduino.turnleft(int time)
Turns the Carduino left for the specified time, in milliseconds.
int mycarduino.proximity()
Returns the reading of the proximity sensor, in centimeters.
Examples:
Go to File -> Examples -> Carduino -> [name of your choice]
Blink- Drives the Carduino forward for a second, stops for a second, and repeats. This should be your first "hello world" program.
Object Avoid- Drives forward constantly, until an object comes within 25 centimeters. Then, it chooses a direction (left or right, chosen randomly) and it turns that distance for a random amount of time, between 800 and 2300 milliseconds.
Cautious Driving- Works like object avoid, but if it notices something within 40 centimeters, it slows down.
Spiral- Drives in an outward spiral.
Examples:
STEP 14: Enjoy
You have now finished everything! If you have any questions, comments, or angry rants, you can feel free to post them in the comments, and I'll try to get back to you. Have fun, and happy Carduino-ing!
23 Comments
sergio.rozenberg.75 8 years ago
muy bueno y facil de utilizar.
master.s.blader 9 years ago
IshanP 9 years ago
can we use this module and normal male to female wires to connect it to the bread board?
http://www.ebay.in/itm/Ultrasonic-Distance-Module-HC-SR04-Arduino-ARM-and-other-MCU-/141472357785?pt=IN_Toys_Games_School_Stuff&hash=item20f068dd99
IshanP 9 years ago
can u pleast tell me the connections for this motor shield?
http://www.ebay.com/itm/L293D-Motor-Drive-Shield-Expansion-Board-For-Arduino-Duemilanove-Mega-UNO-/221541254774?pt=LH_DefaultDomain_0&hash=item3394e34676
i would appreciate if u show the connections using a diagram
katanahikari 10 years ago
I'm having trouble installing the library.
I downloaded the zip file and imported the library, but when I put it in the sketch it only shows the .h file and gives me the error message:
core.a(main.cpp.o): In function `main':
C:\Program Files (x86)\Arduino\hardware\arduino\cores\ard... undefined reference to `setup'
C:\Program Files (x86)\Arduino\hardware\arduino\cores\ard... undefined reference to `loop'
The four "example" files show up in the sketchbook, but each opens in a new window. They individually verify, but when copy/pasting them together I get error messages.
I can't seem to import the .cpp file at all, and when I try to drag and drop it I get the same error message.
12203madman 10 years ago
gadgetnerd3373 10 years ago
jakjakjak 10 years ago
alecnotalex 10 years ago
Keshern 11 years ago
I put this on the Arduinoprogram:
void mycarduino.begin () Call in setup ().
void mycarduino.goforward(float 4, int 12)
void mycarduino.goback(float 4, int 12)
void mycarduino.turnright(int 2)
void mycarduino.turnleft(int 2)
alecnotalex 11 years ago
What exactly did the error say?
Could i use Motorshields from this Collection?
http://www.amazon.de/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=Arduino+Motor+Shield+R3
?? I cannot buy the Motorshield R3 on Amazon.US, because i dont have VISA or a Mastercard.
smaw51 11 years ago
Use BlueTerm from google play to control it.
#include //motor shield
#include //Software Serial Port
#include // android link bluetooth
#define RxD 6 // BT com these are backwards on the shield
#define TxD 2 //BT com backwards on BT shield, jumpers
#define trigPin A4 //sensor trig to analog 4
#define echoPin A5 //sensor echo to analog 5
#define objLED A3 // set obsticle indicator led to analog 3
AF_DCMotor lmotor(2, MOTOR12_64KHZ); // create motor #2, 64KHz pwm
AF_DCMotor rmotor(1, MOTOR12_64KHZ); // sets the left motor to port 1
SoftwareSerial blueToothSerial(RxD,TxD);
void setup()
Serial.begin(38400); // set up Serial library at 9600 bps
pinMode(RxD, INPUT); //set pin 6 to BT in
pinMode(TxD, OUTPUT); //set pin 2 to BT out
pinMode(trigPin, OUTPUT); //sets ultrasonic sensor
pinMode(echoPin, INPUT);
pinMode(objLED, OUTPUT);
setupBlueToothConnection(); //
rmotor.setSpeed(200); // set the RIGHT motot speed to 220 from 0 to 255
lmotor.setSpeed(200); // set the Left motor speed to 200 from 0 to 255
void loop()
//get distance before collision
float duration, distance;
digitalWrite(trigPin, HIGH);
delayMicroseconds(1000);
digitalWrite(trigPin, LOW);
duration = pulseIn(echoPin, HIGH);
distance = (duration/2) / 29.1;
Serial.println(distance);
//end distance
//recieve and execute comands via bluetooth
char recvChar;
if(blueToothSerial.available())//check if there's any data sent from the remote bluetooth shield
recvChar = blueToothSerial.read();
switch(recvChar)
case 'w': //forward
blueToothSerial.println("forward");
rmotor.run(FORWARD);
lmotor.run(FORWARD);
if(distance <= 10 && distance >=1) // stop motor if distance is less than or equal to 10 cm
avoidObject();
break;
case 's': //backwards
blueToothSerial.println("reverse");
rmotor.run(BACKWARD);
lmotor.run(BACKWARD);
break;
case 'e': // stop
blueToothSerial.println("stopping");
rmotor.run(RELEASE);
lmotor.run(RELEASE);
break;
case 'a': // turn left
blueToothSerial.println("turning left");
break;
case 'd': //turn right
blueToothSerial.println("turning right");
break;
}//end switch case
} // end BT com
} // end loop
void avoidObject()
digitalWrite(objLED,HIGH);
//delay(20);
delay(100);
void setupBlueToothConnection()
blueToothSerial.begin(38400); //Set BluetoothBee BaudRate to default baud rate 38400
blueToothSerial.print("\r\n+STWMOD=0\r\n"); //set the bluetooth work in slave mode
blueToothSerial.print("\r\n+STNA=SeeedBTSlave\r\n"); //set the bluetooth name as "SeeedBTSlave"
blueToothSerial.print("\r\n+STOAUT=1\r\n"); // Permit Paired device to connect me
blueToothSerial.print("\r\n+STAUTO=0\r\n"); // Auto-connection should be forbidden here
delay(2000); // This delay is required.
blueToothSerial.print("\r\n+INQ=1\r\n"); //make the slave bluetooth inquirable
Serial.println("The slave bluetooth is inquirable!");
blueToothSerial.flush();
Higgs Boson 11 years ago
DerekK19 11 years ago
Kiteman 11 years ago
