Cat Enclosure
Intro: Cat Enclosure
STEP 1: Make a Plan
Start off by deciding how much space you have in the yard and how much your cats are going to want. Keep in mind that the pipe is cheap and that fancy fittings like the three way joints are what will rack up. I chose my dimensions, 7X5X3, because my cats love to climb and the length and width facilitated three levels of platforms that would fit in the shade.
here was my shopping list:
1.) 12 - 10 foot schedule-40 1/2'' PVC
http://www.lowes.com/pd_23966-1814-PVC+04005++0600_0__?productId=3133079&Ntt=pvc+3-way+1%2F2&pl=1¤tURL=%3FNtt%3Dpvc%2B3-way%2B1%252F2&facetInfo=
2.) 8 - 3-way fittings (most stores have the third direction tapped but Lowes had the right ones in my town)
http://www.lowes.com/pd_315498-1815-413005RMC_0__?productId=3344666&Ntt=pvc+3-way+1%2F2&pl=1¤tURL=%3FNtt%3Dpvc%2B3-way%2B1%252F2&facetInfo=
3.) 24 - T fittings
http://www.lowes.com/pd_26051-1814-PVC+02400C+0600HC_0__?productId=3514896&Ntt=pvc+t+1%2F2&pl=1¤tURL=%3FNtt%3Dpvc%2Bt%2B1%252F2&facetInfo=
4.) 36'' X 50' plastic poultry netting
http://www.lowes.com/pd_157764-13113-090786_0__?productId=3457516&Ntt=poultry&pl=1¤tURL=%3FNtt%3Dpoultry&facetInfo=
5.) ZIP TIES (100 - 150 will be plenty, cheap at dollar tree)
Got it all for $80.00
You might also need:
1.) a pipe cutter
2.) a marker
3.) tape measure
STEP 2: Make the Frame
When cutting PVC you want to endeavor to get a straight cut, if you might not be to confident have plenty of sandpaper.
A note for when you are measuring, fittings add length to the pipe. To get the correct length on the pipe you have to measure to center.
Which means you have to put the fitting on and measure your cut to the center of the fitting (most come with helpful notches).
However I knew that the 1/2'' fittings added 1/4'' per pipe so I measure accordingly (i.e. for the seven foot segments there are two fittings on either side, 3-way, so I cut them a 1/2'' short (1/4 + 1/4).
If you want to follow my plan this is what to cut.
1.) 4 X 6' 11.5''
2.) 4 X 2' 11.5''
3.) 4 X 5' 11.5''
STEP 3: Support and Platforms
I apologize for the lack of pictures here, it started raining and lost focus.
So first you have to take the frame apart of course, the idea for this step is to take your long frame pieces and essentially cut space out for the fittings. My plan called for the length of the pin to be split up into fourths. To do that, take the measuring tape and mark off each 1 3/4' however I did it with fittings on the side (measuring from the center) to ensure the cuts wouldn't be off by a 1/4'' each time. With these marks in place, mark a line a 1/4'' left and right of each segment to allow the T fittings to not add length to the enclosure. once cutting the first pipe down you can use a piece as a template and just cut to match instead of measuring and marking three more times.
After the cutting this is what you should have:
16 X 20.5 inches
STEP 4: Support and Platforms 2
My plan called for three platforms spliting the distance from the ground, 0', and the highest the cats would want to be (away from the ceiling) 4'. With some wonderful math we get a platform every 4/3'. The platform is supported by 4 of the 5' poles which I will call legs.
sooooo since each leg doesn't need a 3 spots cut out for each platform (they are like stairs) they don't need to be cut into equal portions like was done along the length.
Here is the cuts leg by leg:
1.) The first leg will be left as it is (to be used as a door later)
2.) The second leg will support half the bottom platform, cut a 1 1/3' piece but don't forget the 1/4'' less for the fitting, and then take 1/4'' off the longer (3 2/3') piece.
3.) The third leg uses the same bottom as the second, next take a 1 1/3' piece off the longer scrap (minus 1/2'' for the fitting on bottom AND top) and then take off a 1/4'' for the longer top piece.
4.) The fourth leg is pretty much the second leg but upside down! so just make four of the third leg.
5.) The fifth leg is the second but upside down, I cut this to match the fourth's top column but just making four of the second leg should hypothetically work.
To finish off the cross supports, take out one of the 3' frame pieces and use it to measure off six more of them, cut and put it together by now it should be feeling pretty sturdy but if you want to add in some more support go for it. I even considered using 45 degree fittings to add in some super strong triangles but it wasn't worth the extra cost as compared to just more straight across.
STEP 5: Install Platforms and Wrap It in Chicken Wire
For the plastic chicken wire covering, just take the roll of wire on the long side and toss it over the top to the other side, pull it taught and zip tie it all down. The long side will take two goes (and possibly a little 1.5' piece in the middle to close it off), after that all you will have to do are the small sides. On one side cut a flap out (a square without the bottom cut (I only cut one column strip free, it can be seen below)) which you can use to put the cats in, afterwards you can use many things to hold it up, I would recommend bungee ties.
61 Comments
wolfmaker 6 years ago
how does the net hold up i was going to use 72 inch by 100 foot 14 gauge 1 inch by 2 inch mesh galvanized welded wire
because I'm worried that the cat might chew through the plastic netting as she like to chew on fish string i found her chewing on that i took it way from her as thinking that not good for her. im going to make a 12 feet wide x 20 feet front to back with extra panel 3 feet behind the front panel for extra door so that i can go inside and not worried that the cat get out on the street open the first door close it then open the next door if she get out its ok she still in the cat condo. cat condo is what i like to call it and i might add some run in later around the top side panels of the cat condo so she can go up high and look around
Jared_Reabow 10 years ago
KristinS60 6 years ago
diana.diehl1 9 years ago
As a veterinarian who tried to save so many outdoor kitties--or cremate their remains--I heartily disagree with leaving your cats roam outdoors. I used to before I knew better. Leukemia and cars claimed the lives of some of my dearest pets. Yes, they love to roam, but cars, disease, entrapment, cruel sadists who intentionally hurt cats or use them to train fighting dogs are very real dangers. In many areas--even urban areas--coyotes can be a real threat. They kill many outdoor kitties in San Diego as part of their normal hunting patterns. Build a kitty habitat. Save yourself some huge veterinary bills. Cats live longer, healthier lives in your indoor environment. Make it fun for them inside and out. And get them neutered for the sake of the offspring that will be killed in a shelter and the people who have to kill them.
shelbeeray 10 years ago
katerlyn 9 years ago
Very well explained! People need to be informed. Disease AND accidents AND death by coyotes. People need to be informed.
LesB 10 years ago
Letting cats out is not responsible citizenship,
pattiemelt 10 years ago
madhypnotist 10 years ago
RachelleL3 7 years ago
Can it be attached to the side of a house? We want our kitties to access their enclosure through a window.
kajredo 8 years ago
Hi Looks great, how much does it weigh (to move to cut the lawn)? Do you use tent pegs to secure it to the ground? Thanks very much.
gam cad 8 years ago
WendyK16 8 years ago
19kevers 8 years ago
that is so c
VictoriaE4 8 years ago
just a thought, couldn't you use slip sling tee fittings instead of cutting down and inserting "T" fittings to add your supports for the platforms?
ErinW5 8 years ago
tracy.obrien.92 9 years ago
Fantastic job with this how-to! Simple, straight-forward, humorous, lovely! Thanks!
kimvellore 9 years ago
Forgot to add, if you use furniture grade PVC pipes they are UV resistant and so many choices for building clamps and connectors in a similar price range, the hinge is a great choice to add to make a easy door
http://www.snapclamp.com/prices.htm
For a local shop near you
http://www.pvcplans.com/pvc-suppliers.htm
or google furniture grade PVC.
I built one after reading your instructable, thank you and my cats thank you too.
After building I found all the fittings that one could use to make this construction more easy and clean. The fittings are called furniture grade PVC fitting which is specifically used for construction projects like this.
This fitting
https://creativeshelters.com/product/clip_t_83-F
would ave been very useful to strengthen the structure after building it without having to cut the pipes.
The top penthouse is a challenge for the cats to get to so only the most adventurous one will get there. The first day the cats were a little scared but after a few days now they beg every day to go to the playpen.
I used the same chicken mesh under the carpet and used outdoor carpet so there will be no moisture trapped underneath to form mold. For the top most deck I cut out a old plastic table that was in the backyard waiting to be recycled. Will be adding some toy challenges for the cats slowly.
Here is a small list links to get fittings
http://www.formufit.com/
http://www.usplastic.com/catalog/default.aspx?cati...
https://creativeshelters.com/category/white-pvcfit...
http://www.pvcfittingsonline.com/fittings/schedule...
Kim
jbyrd96 9 years ago
