Cat Eyeliner
Intro: Cat Eyeliner
This make-up technique is quick and classy. If you don't have a ton of time to put on make-up, this can be a little trick that goes a long way!
STEP 1: Gather Your Supplies
For cat eyeliner, all you really need is some liquid eyeliner and mascara. For a more dramatic look, you may want to apply eye shadow before as well, although it's not necessary.
STEP 2: Trace the Upper Eyelid With a Thin Line.
Using your liquid eyeliner, begin tracing the outline of your eyelid with a thin line starting at the inner corner and moving outward.
STEP 3: Flick Upwards Towards Eyebrow.
Continue tracing to the outer corner but flick the line away from from the lashes and toward the eyebrow, ever so slightly. It's okay if the line begins to move away from the lash line.
STEP 4: Fill In.
Attach the line you have created to the lash line and fill in. Trace over to make the line bold and flicking upwards the the outer corner.
STEP 5: Repeat on the Other Eye.
Using a mirror, repeat on the other eye. Make sure that the liner is symmetrical.
STEP 6: Add Mascara.
Add some mascara to pump up the volume.
STEP 7: Voila!
Cat eyes complete!
2 Comments
Phoenix Flare 9 years ago
Danger is my middle name 9 years ago
Very pretty! You should enter these in the Hair and Makeup Contest https://www.instructables.com/contest/hairandmakeup/
