Catch 50 Fleas in One Night
Intro: Catch 50 Fleas in One Night
With this home built flea catcher I was able to catch 50 fleas in one night. Yes I certainly did count them!
I have seen several other prototypes on the internet, but I wanted to share my experience with my results.
The part list.
Dish Soap
Ground Black Pepper
LED Night Light
Container Lid
Toaster Over Tray
There are several flea traps on the market. Here is one such example. However they contain a sticky pad that you will need to eventually replace. I am adding this language expressly for the "I Could Make That" Contest. Please vote and share with a friend =)
The part list.
Dish Soap
Ground Black Pepper
LED Night Light
Container Lid
Toaster Over Tray
STEP 1:
This part of the experiment verifies that soapy water will work for the trap, but regular water will not. The soap reduces the water surface tension. Basically this trap wants to drown the flea, not let it glide on the surface of the water. Why did I use pepper? It is similar in size and weight of a flea. If the solution is correct and it pulls a small grain of pepper, then it will definitely pull down a flea into the trap.
STEP 2:
Now that we know how to verify the solution. We take our lid, fill it with water, and squeeze generous amounts of soap into it. The ratio is unclear at this time, but with the pepper it doesn't matter. Simply stir the water a bit and keep adding soap until the when you add a pinch of pepper, it sink right to the bottom of the lid. The tray is here so that my cat doesn't drink the soapy water. I doubt it would happen because soapy water doesn't taste good, but it is here as a precaution.
My best guess on the water to soap ratio: 2 cups water to 4 TBSP soap.
STEP 3:
Okay here you will see the trap all setup and in place. The LED night light is plugged in right above it. The fleas will jump towards the light, and bam they will sink into the soapy water.
STEP 4:
Here are the results. I counted 50 fleas caught in trap in the morning. So I will count this as success.
On the left side of the picture is some of the pepper scattered about, but the rest are in fact fleas.
STEP 5:
As a side note I must say I did see the very first flea land into the water, before I added to soap. The flea just glided onto the water, but once I added the soap the little guy couldn't glide on the water surface tension and sank to the bottom. I must admit that I did feel bad for the little guy. He did thrash around a bit just like any other creature of the animal kingdom might do if they were drowning. This is a warning that this method is non toxic and eco friendly, but it will indeed drown any flea that lands in the trap.
189 Comments
Spongebob66 9 months ago
HelenS20 2 years ago
aiko1113 2 years ago
Lgcinc 3 years ago
Also I vacuumed for 14 days in a row every inch of the place and then I sprayed a small bottle mixing peppermint oil and eucalyptus oil probably 20 drops of each into a typical spray bottle that is the size of a Coca-Cola can... They hate menthol, and it probably killed many of them as well as the vacuuming every day and immediately dumping the vacuum outside in a bag where I tied up the bag and threw it immediately in the trash.
I also went away for 10 days after on a trip but when I came home there were few laughed which was quite annoying they are so stubborn. Here is a photo of catching for more in the sobey dish water plate...
CEVMarauder 10 years ago
It's a ripoff, probably one of the worst on the market. The active ingredient is Fipronil, 9.7%. You can buy 20 OUNCES of 9.1% fipronil for ~$72. It's sold as termiticide; I use Taurus SC2; there's another brand called Termidor. Yes, that is a 2,778% markup!
Take yourself a 1.0ml dropper and apply .5ml to your cat, right behind the head (and I usually put a little bit at the base of the tail.)
Fipronil has little to no effect on mammals. Breeders have been doing this for ages. You can also mix it with water (according to the directions on the package) and spray down surfaces to eliminate fleas and other pests. Keep in mind that while it's harmless to mammals, it's toxic for fish and invertebrates. Read all precautions before using.
Shawneepisme 4 years ago
Tinkonthebrink 8 years ago
fipronil works by neurological toxicity. Many, many animals have seizures in response. Others have extreme discomfort, loss of balance and coordination, excessive salivation, rapid breath and heart rate and skin burns at the site of application. Sometimes this damage does not resolve, and sometimes animals die. Vets have a standard protocol because so many people call with animals in distress from this. Please do not put this on an animal in your care!
SaveOurPaws 10 years ago
Also, Frontline has bene known to cause seizures in dogs, so I don't recomend it.
Advantage/Advantix is best, but make sure you are using the correct one for the species you are medicating. Dog Advantage can kill cats. An alternative for dogs is Trifexis. I have used both over the years with no side effects on either cats or dogs.
dmcneill0814 4 years ago
Pipchip2 6 years ago
PamelaR75 5 years ago
YES! Did this last night and it worked great. Just some dish soap and a tea light. I caught about 50! After spending a ton at Pet Smart :( I will not do that again.
ecoben 6 years ago
I highly disagree with this comment. Most insects cannot see yellow light. Also the research and the whole point of the project was to prove that fleas do not go after heat. Hence a LED light uses less power and is much safer than using a candle.
Lucy2941 7 years ago
ecoben 6 years ago
If you no carpets even better. Fleas tend to lay the eggs in the carpet which can be gross. I would recommend vacuuming and mopping the floors more often. Soapy water with the optional splash of bleach would also keep the floors clean and sanitised.
ecoben 7 years ago
betterways 7 years ago
Thanks. I've done this before & knew to use soapy water. (use soapy water to rinse off a flea comb if you animal is bad enough you need to comb them out.) But you had some useful ideas. And verified that an LED bulb will work, which is the info I was searching for. Please, everyone, don't use sticky traps. I caught a gecko in mine which I didn't want. Especially never use those glue traps for rodents. They can catch a lot of things you wouldn't have wanted to harm. I volunteer at a wildlife center and we often have to deal with birds stuck in the traps.
ecoben 6 years ago
Great to hear this project is helping the wildlife. The whole point of the project was the keep fleas under control without negative effects to the environment. Great to hear that this works better than sticky traps.
ecoben 7 years ago
One part of the project was to make a cheap flea trap. This trap only uses a few drops of soap. Using lots of dish soap would create a similar affect, but soap costs more than using water.
Again you do not need a heat source, but you do need a light source. But if you are catching fleas everywhere you may need to thoroughly clean your room. The traps you are using are working from the fleas randomly jumping inside VS using a beacon to get all of them out of your room.
laudlina 7 years ago
Hey! This sounds great and has already helped a little (caught some of them).
I have one question though - can I use the same water multiple times? I mean should I make a new soapy water for every night or can I use the water from last night if there are not too many fleas inside?
Thank You!
ecoben 7 years ago
I'm sure you can you use the same water for the week. Eventually the water might get dirty, it might evaporate, or the fleas in the water might be gross. Use your best judgement. I have found after the first night most of the fleas for that room have been trapped. But you could keep it going for a few nights to see what happens.
