Caulk Silicone Sealant Holder Instruction Guide
Intro: Caulk Silicone Sealant Holder Instruction Guide
The Fault
Lack of storage solutions available from factory options in commercial vehicles
Most commercial vehicles, van and camper conversions have limited storage solutions. They often come with the rear of the vehicle completely bare except from the MDF cladding on the inside of the shell.
Our Solution
Install X8R’s caulk and silicone tube holder in under 5 minutes for a simple storage solution.
X8R’s caulk and silicone tube holder is the perfect solution for tradespeople such as plumbers, electricians, decorators etc. It holds up to 5 tubes, with the right-most hole made slightly larger to accomodate a caulking gun (with or without the tube inside the gun).
The holder can be fitted with self-tapping screws for an easy installation (with or without power tools) in under 5 minutes.
The bracket could also be wall-mounted such as in garages, workshops, sheds etc. Please ensure you use suitable wall plugs (if necessary).
The bracket is made from 1.5mm thick black powder coated steel, a far superior material versus the inferior plastic other solutions which often break.
Compatibility
The bracket is compatible with all caulk, silicone, adhesive tubes etc with a diameter of 2 inches or less.
You Will Receive
1 x Caulk/silicone bracket in powder coated steel
STEP 1:
Press the bracket against the wall you're fitting it to. Ensure it is level with a spirit level. Mark the holes with a pen.
Use a screwdriver/electric drill to install the top screws into the holes. Then follow with a handheld screwdriver for the bottom holes.
This completes the installation. If you need any further guidance on this install or would like to purchase the parts shown please call us on +44 01843 446643 or email us at sales@x8r.co.uk. Please also check out our instruction guide on YouTube. www.x8r.co.uk Installation is carried out at installers risk, if unsure please contact us or a professional, X8R Ltd cannot be held responsible for any adverse result of installing this product or any injuries caused by install, if in doubt ask a professional. All images and texts are copyright X8R Ltd 2024.
