Cell Phone Charger From an Old 9V Battery
Intro: Cell Phone Charger From an Old 9V Battery
This instructable shows how it's possible to make one 5V usb charger from an old 9V battery, useful to charge cellphone's batterys.
The charger in the picture it's already working - it already charged my cellphone last night. But it still needs to be closed inside some case, that should be the 9v battery case kept from it's disassembling process.
However, here goes the instructions, with the electronic scheme included...
STEP 1: Materials
The picture shows the components needed to assemble the charger, including one empty case from an old toothpaste, that can be useful to put the charger inside in the future, in an updated step...
And the list of components and materials is:
1 old 9v battery
1 USB port type A (female)
1 Regulator 7805
1 green LED
3 resistors 220R
1 empty case (optional)
solder
wires
1 old 9v battery
1 Regulator 7805
1 green LED
3 resistors 220R
solder
wires
STEP 2: Schematic
In the computer, using any electronic circuit maker, can be made one scheme like the one in the picture, where I've added a diagram of the pinout of the regulator 7805 and of the USB port.
STEP 3: Solder the Components
After the disassemble the old battery, the base with the connectors it's useful to solder the components on, starting with the Ground pin of 7805 (pin 2), soldering it directly to the negative pole.
Pins 1 and 3 must be softly lifted up, in order to solder the other components, according with the scheme of the previous step.
One resistor is connectd in the positive pole with a minor size than the base, in order to connect to the Anode of the LED, making a series from the positive 9V pole to Pin 1 of the Regulator.
Pin 3 of the regulator (output 5V) is then connected directly to pin 1 of the USB port, soldering a wire.
The Data pins of the USB connector are connected with 2 pull-up resistors to the pin 3 of the regulator
To finish, pin 4 of the USB port it's connected with a wire to the negative pole of the battery, where it's already connected pin 2 of the regulator.
The result must be like shows the picture, where we can see the charger charging the battery of my mobile and we can read in portuguese: "Bateria está sendo carregada" - Battery is being charged... ;)
STEP 4: Final Product
And the final product must be like it's shown in the picture! Now I have one mini-charger, handy to have in the pocket with a battery, for the urgencies. ;)
25 Comments
daniellong2 8 years ago
this is probably not going to charge the battery, but it will work as an external battery (the phone uses the 5v input instead of the internal battery) because I already tested it and the only thing that happened is that the battery level was always the same until the 9v got depleted
Bharath bhushan royal 6 years ago
AbhiR8 7 years ago
What if i use 2 sony rechargeable 2700 mah Battery replace to 9v battery and connect to solar plate?
is this possible??
i think i can use circuit of Small car mobile charger
ping me about it
MobiOnC 7 years ago
You can now charge your laptop or mobile online. No charger required. Check out the Online Charger website - www.onlinecharger.com
S.m.V 7 years ago
can i use potentiometer to maintain 5v supply
solferntc 7 years ago
And if i do that but with a 10.8V DC laptop battery? Would it charge the cell phone faster and last longer?
jaimealmeida 7 years ago
ishaans9 7 years ago
First you must know that this is not intended to charge the phone - it's only for urgencys... The 9V battery supplies about 25mA, which means that it would need about 100h to charge the battery of the phone, but what happen's in the reality is that the 9V battery will discharge very quick because of the inner resitance of the cellphone is low.
Gomi no Sensei 8 years ago
Most smart phone batteries are 1500-3300mah.
A 9V battery has 50-400mah and at 500mw load has less than 300mah capacity.
You're also losing 30% of that 300mah thru the 7805 as heat.
Just exactly HOW much does this remaining 210mah charge your phone ???
Ref : http://www.powerstream.com/9V-Alkaline-tests.htm
ajithgopi 8 years ago
Why is data needed for charging?
hyderabad2001 8 years ago
Thanks for helping me out
jaimealmeida 8 years ago
at home you can find 5v regulator at every Power station of many devices, like PC's, DVD reader/writer, etc. Every equipment that needs 5V to work, uses a regulator like the 7805 or other to assure the right voltage.
But, if you're looking to scavenge an old equipment to get one 7805, Forget it, because it already has many hours of work and it's not the same as one brand new for sure, that is very cheap...
copeland.royall 9 years ago
jaimealmeida 9 years ago
It really works, but you have to be carefull, in a way to don't let any pin to touch each other, avoiding any short-circuit between all the components in the circuit. It's the most dificult in this charger is to keep all the parts isolated...
efahrenholz 10 years ago
jaimealmeida 10 years ago
Thank you for your suggestion, but this is supposed to be an easy way to construct one cheap mini charger, that has many alternative possible solutions to be constructed and updated, like the way you suggest. I just didn't even think about the life of the battery, because it's just another old battery that I've made good use from scrap...
