Centaur Costume With Walking Legs and Cooler From Unicorn City and Battle Axe
Intro: Centaur Costume With Walking Legs and Cooler From Unicorn City and Battle Axe
I passed out drinks this year as I cruised Halloween as a Centaur! The character comes form an indy film, Unicorn City.
see how the legs work as i walk. It also has a drain in the back so it could go potty when the cooler drained. ;)
STEP 1: Build the Body
I took the wheels off of a Barbie bike and mounted them to an old piece of aluminum from a broken chair. I then mounted this to the cooler with zip ties that mounted through holes i drilled through just the outer layer of the cooler.
I used these tubes and mounted them vertically. This comes in later and is helpful in making the legs move later.
STEP 2: Carve the Legs
Using an electric bread knife, I carved these out of foam board insulation. I couldn't find the thicker board here locally, and just used thin sheets i had on hand and glued 2 layers together to get the thickness. The serrated knife helped make fur texture.
STEP 3: Painting and Fur
A couple cans of spray paint always bring everything together. I did the wavy lines to be inline with the Unicorn City movie character.
Also... when in doubt... put fur on it! i made a neck line, cuffs, leg pieces and loin cloth to hide the seems of the shirt. We also put fur on the handle for a tail.
STEP 4: Mount the Legs
I attached the bottom of each leg with one bolt to the spokes. This offset could make the legs "walk"
The upper end, i attached a rod with some wire and fitted that down the tube that was holding the wheels on. That way, when the offset bolt rotated, it would drive the upper part of the leg up and down like a piston. watch the video to see it walk https://www.youtube.com/watch?v=gWy9cSGfIO4
STEP 5: How to Make a Battle Axe
I drew an axe profile in CAD and lasered out of 1/4 inch plywood. I then attached that to abroken broom handle... added a bit of spray paint and fur.
10 Comments
neciavanderlinden 8 months ago
552527077 2 years ago
创意:★★★★★
实用:★★★★★
ka3ros 2 years ago
barb.at.harbour.main 2 years ago
vbanaszak 2 years ago
Alfetta159 2 years ago
wimton 2 years ago
TechnoChic 2 years ago
hugheswho 2 years ago
Alex in NZ 2 years ago
