Introduction: Duct Tape Station
Make a station for your different kinds of tape.
Step 1: Tools and Materials
Tools You will need:
1 sander
2 drill motor
3 router
4 tape measure
Materials:
1 plywood 3/4
2 hacksaw blade( preferably 18. inch
3 screws. 1-1/4 inch
4 Piece of PVC pipe. 5/8 inch.
5 Stain or paint. which ever you prefer.
1 sander
2 drill motor
3 router
4 tape measure
Materials:
1 plywood 3/4
Step 2: Cut List
Your Need:
6# 6x6 inch squares
1# 17L x 6W inch
1# 20L x 6W inch
2# 6L x 2W inch
6# 6x6 inch squares
1# 17L x 6W inch
1# 20L x 6W inch
2# 6L x 2W inch
Step 3: Construction
Basically you can see the set up in the pictures. The longer piece goes on the front and the shorter on the back. The 6x6 squares go inside at every 2-1/2 inches. NOTE: Make sure they are 2-1/2 inches from inside to inside.
Step 4: Side Rails
The 2x6 pieces go on the sides. They are screwed in with three screws. You will have to drill 5/8th. inch holes in the top.The PVC pipe goes across and fits inside both sides. I made mine short enough that I can pull it out and/or snap it back in so I can change the tape rolls easily.
Step 5: Stain
Stain or paint it whatever you prefer. Don't forget to sand it.
Step 6: DONE!!
All done! Now you have a central location for your tapes.
