Chain Maille Ring Maker Mini Sized
Intro: Chain Maille Ring Maker Mini Sized
NOTE: This is for chain links that you want very small and for a tight weave!!!!!
This is my second instructable so feel free to comment about how well i did or if i didnt do a good job so i can improve if needed.
STEP 1: WHAT YOU NEED!!!!
a peice of copper pipe(i prefer the L shape or T shape fitting it makes it last longer)
A Nail
Like those long and pretty thick nails it must be almost unbendable using bare hands
OR instead of a Nail you can substitute a metal rod your call
A hammer
A hack saw or some thing that can take the head off the nail. you can also use big bolt cutters
Super glue
A hitting surface i have a anvil so im set.
STEP 2: Take the Head Off the Nail
IF you dont know what the head of a nail is then it is on the left side of my fingers
STEP 3: Putting on the Copper Pipe
I used a copper pipe for the one on the opening page and its about to break at where its bent at a 90 degree angle so i would strongly suggest pipe fittings made of copper
ok first take the copper fitting and put it like the one in picture 1
NOW take it and hammer the copper flat so it makes a crank with the copper fitting
MAKE sure there is a space here like in picture #2 cause that is where you insert the wire.
The end result should look like picture #3(dont freak out i had one premade cause i have 2 for 2 different sizes)
STEP 4: NOW the Super Glue
Put super glue here and apply it liberaly cause you dont want this slipping or coming loose.
STEP 5: How to Make Chain Links
THIS video is easy to follow.
If you have to download this then sorry for the inconvenence(cant spell)
STEP 6: This Is My Armor So FAR
A good site to visit to get alot of good pictures and weave instructions is here
http://www.mailleartisans.org/
just go to library and then go to weaves if you are a beginer to this art then start with european 4 in 1.
Hope you will find this helpful
5 Comments
acoleman3 12 years ago
lunius 13 years ago
combatbootboy 13 years ago
Out of curiosity, what do you use to cut the wound up wire? Just wondering what the best tool for that job would be.
lunius 13 years ago
