Chair With Tire
Intro: Chair With Tire
In this instructable I bring you an idea of how to recycle your old car tire without having to throw them away. This idea is very economical and above all that you can decorate in the house that you like, use it as a table or chair you can use as you want. Let's start!
STEP 1: Tools and Materials
We'll need:
- A tire
- Wood with 55 cm about diameter
- Eight crews
- A drill
- Silicone
- Brush
- Varnish
- Rope
STEP 2: Adhere the Wood at Tire
Clean the rim and wood and let dry completely. Use the drill four holes drilled deep enough to penetrate the rim. Depending on the selected screw, use a screwdriver to tighten repeat on the other side of the tire cover.
STEP 3: Put the Rope
The rope must put in the center of the circle in order to get a perfect finishing touch . Press the tip to stick well and wrap the snail shaped rope. When you finish covering the surface of the wood, put enough silicone in the wood edge and tire to ensure that the union of the wood and the tire is hidden.
STEP 4: Cover the Tire
Spin the wheel down and continue covering the tire, when you finish put enough silicone at tip.
STEP 5: Cover With Varnish
Put some varnish to add shine and this will also serve to harden a little rope. Let it dry and ready.
2 Comments
aloomis1 9 years ago
