Change the Led's From Your Keyboard
Intro: Change the Led's From Your Keyboard
This is another easy but cool project for you to do with your keyboard .
Probably you're tired of the green LED's from your keyboard and you want some other color ? Or you may want a different color for every LED on your keyboard ? This instructable will show you how to change the LED's from a standard computer keyboard.
STEP 1: Tools and Materials
The materials you need are the 3mm replacement LED's , nothing else is needed.
The only tools you need are a soldering gun and a screwdriver.
STEP 2: Take Everything Apart
The first thing you wanna do is get your screwdriver and start removing all the screws from the keyboard.
After that , put the keyboard on your desk and remove the keys side . Some keyboard use springs for the keys , some other ones (like mine for example) use a plastic layer which acts exactly like a spring . So if you have this layer , remove it (it's transparent and looks like a very large button array) . After removing the keys you will see the main circuit board and two transparent plastic foils full of electrons and circuit patterns . You will have to remove that . To do this , find the metal blade which connects the foils to the main board , and remove the screws from it , and after that gently pull the foils out of the keyboard.Next unscrew the main board , remove any connector and you will end up with only the main board .
STEP 3: Change the LED's
Now you can change the LED's . First get your soldering gun , flip the board , and heat up the solder layer of the LED you want to change . Also press the gun on the board , so the LED will get out of it's connectors when the solder heats up.Also remember where the flat side of the LED was before you removed it ! LED's are polarized , so they need to stay in a certain direction in a circuit . You need to remember where the flat side was to know in what position to put the new LED.
Now , get your new LED and cut it's pins to the same length as the original keyboard LED .
Insert your new LED in the old LED's place and then solder it's pins.Remmeber to put it with the flat side in the correct direction !
Do the same for every LED you want to change .
STEP 4: Let's Test !
Insert the keyboard cable to the PC .
Now get your modified board and reatach the connector . All the LED's should flash . If they don't , then there is a problem : the LED might be wrong - sided or it's a burned LED . If they all flash correctly , you did it ! .
Now reatach everything , be careful with the two transparent foils !
STEP 5: Let's Look at the Finished Product .
Here is how mine looks like .
I hope you liked my instructable !
12 Comments
drresearch 13 years ago
azbo1 12 years ago
spider87 13 years ago
phenoptix 14 years ago
punkatsub 14 years ago
Vladmakesstuff 14 years ago
marselsipod 14 years ago
Corpy 14 years ago
the_mad_man 14 years ago
