Chapter 4, Parallel Circuits
Intro: Chapter 4, Parallel Circuits
In this chapter, we will cover the following:
1. Parallel Circuit Definition
2. Voltage in Parallel Circuit
3. Current in Parallel Circuit
4. Resistance in Parallel Circuit
5. Designing Parallel Circuits
6. Designing Parallel Circuits to Specification
7. Sources in Parallel
8. Current Divider
9. Power Dissipation
10. Differences Between Series and Parallel Circuits
It is imperative that you have a working knowledge of series circuits. If you haven't done so, go over Chapter 3 to learn about series circuits.
8. Current Divider
STEP 1: What Makes a Parallel Circuit?
STEP 2: Voltage Is the Same in Parallel Circuits
STEP 3: Current Is Additive in Parallel Circuits
STEP 4: Total Resistance Is 1 ÷ the Sum of the Reciprocals
STEP 5: Designing a Parallel Circuit
STEP 6: Designing a Parallel Circuit to Specification
To view the full diagram
click
https://www.facebook.com/media/set/?set=a.365127546849944.104121.100000581067443&type=3
click
STEP 7: Design to Spec 2
STEP 8: Sources in Parallel
One technique to increase current in a circuit is to place power sources in parallel.
Adding another voltage source in parallel to existing voltage sources will not increase total voltage (VT), rather, as stated above it increases the current. To increase total voltage, one must place the additional voltage source in series with the existing voltage source.
Important!
When placing voltage sources in parallel, ensure that all the voltage sources have the same value. If the voltage sources in parallel are not the same value, there is a very high possibility that your voltage source/s will explode.
For example, if V1 = 12V, then V2 and V3 must also be 12V.
Important!
STEP 9: Current Dividers
STEP 10: Power Dissipation in a Parallel Circuit
STEP 11: Differences Between Series and Parallel Circuit
Dear Geeks,
There will be updates on this chapter (CH 4) to further explain the concepts. So check in every 2 weeks for updates. If you have any comments, suggestions or questions, don't be shy to post.
Elektrobot
Elektrobot
8 Comments
benjamin,johannesB 7 years ago
thank very much
bosstune 12 years ago
elektrobot 10 years ago
thank you for your feedback.
fbmimi 11 years ago
thanks for commenting
russ_hensel 12 years ago
Batteries are voltage sources ( with an internal resistance ) In the case of your circuit the current is 12 micro amps. With one battery or a million ( current the same to a few pico amps ). Please recheck this section, I think you will see your error.
elektrobot 12 years ago
thanks for pointing that out. I uploaded the corrected figure.
elektrobot :)
I apologize for not adding much to this material this month. I have been lazy lately. I'm also stressing on finding the perfect apartment for myself and my cat (her name is mouse). Budget and perfect apartment is not an easy task.
Anyway, I will try and add to this section this coming March. Have a nice day!
elektobot
