Introduction: Charge CD Player Batteries Without Opening the Lid
I use a Sony MP3 CD player to listen to Podcasts and to my audio Bible, also MP3. I have NiCad AA batteries in it. They were free. But, if I need to charge them, I must open the lid to get at the battery compartment. That causes my place in my audio program to be lost. I wanted to be able to charge the NiCad batteries without losing my place.
Step 1: Open the Player
The red arrow points to the door of the battery compartment. The red squares show the locations of the screws that hold the player together. As you know, avoid touching the reader lens with your fingers. The lime green arrow points to the power jack.
Remove the screws. Pry the case of the player open.
Step 2: The Goal
The photo shows the circuit board. The black screwdriver bit points toward the power jack (yellow plastic) and a shunt I soldered between two points on the circuit board.
The player's power jack is designed so that the connection to the batteries is broken and only external power flows to the player circuitry when the power supply's plug is in place. In time the power jack's internal connections loosened. The least movement while listening often caused the power connection from the external supply to be lost. That also caused my place in my audio program to be lost. It was frustrating.
The solution was to use the external power jack and supply to feed charging current to the batteries. Making that possible meant adding a shunt so the batteries are not locked out when the external power supply's jack is inserted. See the next steps for the circuitry and how to know which solder connections to shunt.
Step 3: How the Power Jack Works - Part 1
Below is a pictorial schematic on the player's jack circuitry. One cell is shown, but there are actually two. The red lines and the red center post are electrically positive. The black lines are electrically negative.
Here you see the circuit as it works without the external power plug inserted into the player. Note the closed contacts that are part of the negative side of the female power receptacle.
Step 4: How the Power Jack Works - Part 2
Here you see the power jack inserted into the player. Notice that the contact points have been pushed open by the power plug.
The power jack is center point positive. The inside of the jack is mostly plastic. But, there is a curved piece of metal that makes contact with the external part of the male power plug. See the black curved line. When the male plug is in the player's power jack, the battery is cut out of the circuit.
Step 5: The Shunt
The plan is to add a shunt (azure blue line) to keep the battery from being locked out of the circuit.
After the player's circuit board is out of the player, use your ohmmeter to get a clear understanding of which solder joints go to which conductors in the player's power jack. Determine which solder joint on the circuit board connects directly to the negative terminal in the battery compartment. Which terminal connects to the negative terminal in the battery compartment when the male power jack is not inserted into the player, but is not connected when the plug is inserted? Connect it with a shunt to the solder joint always connected directly to the negative terminal in the battery compartment.
When soldering on the circuit board, be careful that no solder forms an unintended bridge to another solder joint and shorts something out.
My charging time is about 45 minutes. The batteries go down quickly when the number of bars in the power indicator on the display get below half full. The batteries I use were already used in another application, so I do not worry too much about overcharging them. I can get more.
It is possible to listen to the player while the batteries are charging, too.
