Charging Lithium - Ion Battery With Solar Cell
49,567
88
15
Introduction: Charging Lithium - Ion Battery With Solar Cell
This is project about charging Lithium - Ion battery with sollar cell.
* some correction I make to improve charging during winter.
** solar cell should be 6 V and current (or power) can be variable, like 500 mAh or 1Ah.
*** diode to protect TP4056 from reverse current should have low drop voltage ("drop out"). I use bad, which take 0,5-0,6 V, which is a lot. You can use Schottky diode, which take only 0,1 - 0,2 V.
Step 1: Material (links Are Affilliate)
1 x Solar cell 6V
Link:6V 1 W
Link: (more cells with different watts)
Link: (more for choosing)
1 x Li - Ion charger board TP4056 (choose board with 4 output - 2 for battery, 2 for connecting device)
Link: (5 pieces, cca 0.20 $ / piece)
Link: (1 piece, 0.29 $ / piece)
1 x Schottky diode (better, 0,1 - 0,2 voltage drop) or 1N4148 (worse, 0,5 - 0,6 voltage drop)
Link:(set of diodes) (updated)
Link:(1N4148)
1 x Lithium - Ion battery (18650), I buy 1 poor, you can choose better with capacity around 2000 mAh - 3000 mAh,
Link:Lithium - ion battery
1 x Lithium - Ion battery holder
Link:battery holder
1 x cables, I use internet cables with 6 wires inside or awg 22 wire kit
Links:
quality: set of AWG 22 cables
ethernet cable: ethernet cable (need to cut off 6 wires)
1 x solder tools (station, tin, rosin etc.)
Step 2: Right Solar Cell
* solar cell should be maximum 6V, because TP4056 has maximum input 6V. It is better then 5V.
* current from solar cell (or power) can be variable, because TP4056 "eat" as much as it need. So you can choose 500 mAh solar cell or 1 Ah solar cell.
For Li - Ion battery I choose solar cell with 5V and 160 mA. For choosing solar cell, you must choose:
1. voltage of solar cell 1.5 x voltage of battery, so 3.7V to 4.2 V of Li-Ion is equivalent of 5.55 V to 6.3 V of solar cell.
2. current of solar cell should have 1/10th of capacity battery diveded by 1 hour (for Ni Mh batteries). I use same rule for Li - Ion battery. It is called C - rate rule. So If I have 500 mAh battery, I should choose 50 mA sollar cell. Good Li- Ion batteries have 2000 mAh, so current should be around 200 mAh or 1.2 W.
I use bad Li - Ion battery with measured around 600 mAh. For that, I should choose solar cell with 60 mA peak, or 0.360 W (POWER = CURRENT X VOLTAGE).
Step 3: Lithium - Ion Batteries 18650
I find good website with tests lithium - ion batteries. Mostly there are 3400 mAh maximum.
Here is: http://lygte-info.dk/review/batteries2012/Common18650Summary%20UK.html
Here is some theory of charging them:
https://www.instructables.com/id/Li-ion-battery-charging/
https://www.instructables.com/id/SOLAR-POWERED-ARDUINO-WEATHER-STATION/
Step 4: Circuit
Circuit is simple, but I describe it here.
Connect positive terminal of solar cell to anode of diode. Connect negative terminal of diode to IN+ (input positive) of TP4056. I use diode because of reverse current.
Also connect negative terminal of solar cell to IN- (input negative) of TP4056. Finally connect battery, positive terminal of battery to BAT + of TP4056, similar negative terminal.
Step 5: LED Diodes on TP Board
On board, there are 2 diodes, which also consupt some power. I remove them with knife. Check picture.
Step 6: Calculation of Efficiency
Test you charging, you can connect your multimeter to solar cell, or battery.
Test:
cloudy, with a little sunny 10 mA (output current from TP4056), 24 mA (from solar cell)
cloudy, not direct to sun 0.87 mA (TP4056), 5.1 mA (solar cell)
sunny, direct sun 26 mA (TP4056), 89 mA (solar cell)
According pveducation.org website, you can calculate direct solar radiation in kW. Just fill your home lattitude and longtitude. And remember time, because radiation during day vary. I got around 1 kW/m2.
So, solar cell give me 89 mA, and 5V, so it gives 445 mW, or 0.445 W. Surface of solar cell is around 70 cm2 (basically only small lines make energy, so around 30 cm2).
Solar cell output = 0.089A x 5 V = 0.445 W
TP4056 output = 0.026 A x 4 V = 0.104 W.
To calculate how much solar radiation fall on 30 cm2 according pv education website, we must convert surface to m2, it is 0. 00 30 m2. Incident radiation is 1000 x 0.003 = 3 W.
Incident radiation = 3W
Efficiency of solar cell = 0.445 W / 3 W = 0.1483 = 14.8 %.
Efficiency of TP4056 = 0.104 W / 0.445 W = 23.37 %
Total efficiency of system = 0.104 W / 3W = 0.034666 = 3.46 %.
So total efficiency is not much, but helps. Do you remember C-rate? For this project, the bigger solar cell is necessary. I test on september, which is average between winter and summer. I use battery for my esp logger, which must survive during winter, summer is good. I will test others solar cells, in future, and show my results.
Step 7: Extra: Thingspeak Graph
I test battery voltage with my esp logger. I got graph on thingspeak. Results are in ADC values, not in voltage. Values 720 is equivalent of battery with 4.07 V. I use bad 600 mA Lithium - Ion battery.
Be the First to Share
    • Rice & Grains Challenge
    • Puzzles Challenge
      Puzzles Challenge
    • CNC and 3D Printing Contest
    15 Comments
    twitchhisparemi
    twitchhisparemi
    Tip 6 days ago
    Couldn't you use a dc dc 5v 1a boost converter so that the current is 1a and put a schottkly diode on it?
    BalasubramanianC
    BalasubramanianC
    6 months ago
    appreciate your DIY on solar charging. how are we addressing the safety of the circuit, esp when 18650 is being used, which is sensitive to voltage fluctuations and might result in fire hazard, if handled improperly.
    my concern / query :
    TP4056 input voltage range from 6 volts to 8 volts. you are using 6V solar panel.during peak time of charging , how do you ensure that your input voltage doesnt cross 8v? if it does then its going to be dangerous to the circuit right? i mean safety aspect of the circuit.(since 6v solar panel can deliver up to 9volts at its peak.).
    in addition to input diode , should we have something else as addition to drop the voltage to 8v incase it exceeds the same? in this case we know max is 9v for solar panel output.
    kindly suggest.
    Michal Choma
    Michal Choma
    Reply 6 months ago
    I think diode drop some voltage. That drop depend on current, bigger current from solar cell, higher drop. So during very shine, current is high and drop also. Try to check graph - drop vs current in diode datasheet
    shakikur1312
    shakikur1312
    2 years ago
    I have a 3watt solar cell..it gives 10v on no loads and approximately 7v 300mah on loads on sunny day.i want to make a garden light with this.i want to use 3.7v 4000mah li-poly batery to charge from solar cell with tp4056 module.can i use 7805 or lm317 voltage regulator ic?
    PospaPunk
    PospaPunk
    2 years ago
    I read here (https://www.best-microcontroller-projects.com/tp4056.html) that "If you have a load connected to the battery then this will change the current detected so the TP4056 may never terminate the charging process.".
    I would like to know your opinion, sice i think most users will use it for charging with load.
    Michal Choma
    Michal Choma
    Reply 2 years ago
    hello, i dont know. I think best is testing with multimeter. It is possible to damage battery because TP4056 will always pump battery with current?
    PospaPunk
    PospaPunk
    Reply 2 years ago
    That is my point. Even if the module with output pins is used, it seems it will still charge the battery when load is connected. Overcharging LiPo may damage them or even worse.
    Michal Choma
    Michal Choma
    Reply 2 years ago
    and I think, better TP4056 module is version with 4 output pins, 2 pins for load, 2 pins for battery. So battery can be fully charged and load will be powered from solar cell.
    samm316
    samm316
    Question 4 years ago on Step 2
    Hi
    Could you give me some further explanation why you choose solar panel voltage to be 1/5 of battery voltage and solar panel current to be 1/10 of battery current divided by 1 hour.
    Regards
    sam
    Michal Choma
    Michal Choma
    Answer 4 years ago
    I hope you understand, and basically choosing solar panel depend on TP4056, not battery.
    Michal Choma
    Michal Choma
    Answer 4 years ago
    voltage - input of TP4056 must be higher then 4,2 V so I choose 1.5 times bigger voltage.
    Current - C-rate law. I just check what usually is charging current for lions battery - it is around 500 mA, but smaller currents are good , too. Also, during summer, the battery is charge fully + as temperature increase, the voltage of battery is higher. I dont want bake battery.
    llaci80
    llaci80
    hi why not use scotty diode? example 1N5819 5819 1A 40V SCHOTTKY DIODE?
    voltage drop not 0,6-0,8V only 0,1-0,2 V ?
    Michal Choma
    Michal Choma
    Answer 4 years ago
    It should be better, and I think if is need to use any diode. I use that diode, and if it not sunny, solar cell e.g. give 5 V, but after diode, votlage is less then 4,5 V, so charging is cut. Not good, I must improve it.
    NicholasP95
    NicholasP95
    Hi, can you tell me how to know if the circuit is charging the li-ion battery or not?
    Michal Choma
    Michal Choma
    Answer 4 years ago
    It is possible via leds. I remove leds, but also, you can try to measure voltage on that places, where leds were. How, I dont know exactly, but try to use analog pins, or digital pins on arduino/esp8266.
