Cheap 1/2" PVC Check Valve
Intro: Cheap 1/2" PVC Check Valve
There are not many cheap check valves at the hardware shop. Since I'm only testing some pump application, I need to have lots of low medium pressure check valves. Here's a cheap way to make one.
Items needed :
1. 3/4" PVC coupler
2. 3/4" to 1/2" PVC reducer
3. Approx. 1" long pin (see diagram)
4. Few glass marbles
5. PVC pipe glue
Howto:
Follow the steps or please download the original image for bigger viewing and reading.
Disclaimer:
The commercially brass type check valves are better for prolong usage. This DIY cheap check valve is only for my testing purposes. Any DAMAGES/INJURIES/DEATH due to this design, I'm not responsible.
Thank you for viewing.
Items needed :
1. 3/4" PVC coupler
5. PVC pipe glue
Howto:
Disclaimer:
STEP 1:
Insert glass marble into the 3/4" side of the reducer. Smoothen he inside of the pipe if the marble doen't fit. Test the airtightness by blowing or immersing in water. Test a few marbles and choose the best.
STEP 2:
Measure the location of the pin location, approximately twice the diameter of marble. Or it can be any dimension so long as it is within the reducer length. Should have room for the marble to move.
Poke a hole on the 3/4" side of the reducer. This to accomodate the pin which will be the rest for the marble during back flow.
Insert the pin, and finished it off with a well flushed finish with the outer surface of PVC pipe.
Make sure the pin is tight fit.
STEP 3:
Finally, insert the coupler. Make sure the laps are airtight, and the coupler totally covering the pin area.
Test by blowing again.
The coupler and reducer should be glued together during final installation.
Thanks.
Thanks.
8 Comments
penukang 12 years ago
charlessenf-gm 9 years ago
"hand pump for my 6ft self drilled 2" pvc pipe well" Well, pardon te pun, why not post that here as well (Oh, no, not again!). I would like to see what you did. BTW The reason I stumbled upon your valve solution was my intent to use some hot water to feed my ceramic toilet in the Summer months when the ice-cold well water caused significant condensation on the toilet tank body - which, then, drips onto the floor and can cause problems. I needed to be able to allow a flow from the water heater only when the toilet demand went 'high.' So, with a hot and cold line running to the toilet fill valve, I get what is needed. But, when there is a demand for cold water elsewhere in the system, I needed to prevent 'hot' water from flowing in response to that demand. Using a check-valve in the cold water source line, then a 't' fitting to allow joining a hot water line to the feed for the toilet tank, i should get the desired result.
HoldOnTight 12 years ago
Excellent ible, well presented with diagrams, distances & sizes, very complete!
5 Stars!
"Some third world countries rely upon pumps like this to get water out of the ground from a well" You may be thinking of a RAM PUMP - use right here in the US of A. But, not to get water out of a well - rather to raise flowing water vertically. e.g. When the strong flowing stream is below the elevation of the crops to be watered or the pond to be filled. search here for "World's Greenest WATER PUMP" to see one excellent exaple.
Lovely. And, as another has said, "elegant!" Thank you for sharing.
Bill WW 10 years ago
Very nice, elegant even. Simple, no spring; the coupler covers any leak where the pins were inserted.
I will be making a check valve, but smaller, using the marble principle. Will likely post it on this site.
Thanks
heathbar64 12 years ago
esemjay 12 years ago
