Cheap Arduino Controlled 3-Axis Pen Plotter
Intro: Cheap Arduino Controlled 3-Axis Pen Plotter
The program reads binary 0's & 1s stored in a word array in row/column fashion & then controls the motors accordingly. You can change what it prints by changing the data in the "image" array. It's pretty basic & shouldn't be too hard to understand or change to fit your wants better.
I included the schematic I followed for wiring the H-Bridge Motor Drivers (SN754410NE). I apologize for not having a complete schematic I have not found an easy way to make them. I used an LM317 5V regulator for each H-bridge, but honestly since I used a computer power supply to give me 5V you shouldn't even need the LM317's. You could just take the 5v from the power supply & wire it to each H-Bridge. In my case I built the control board before choosing a power supply.
Part List Quantity CostTotal
H-Bridge Motor Driver 1A (SN754410NE) 3 $2.35 $29.25
Voltage Regulator (LM317) 3 ~$1.95
10uF/25V Capacitor 3 ~$0.45
Used CD-ROM 3 ~$5.00
Arduino Duemilanove/UNO (This indestructible assumes that you already have one) ;)
If you don't already have an Arduino the total cost will be closer to $60.00.
In case you don't want to download the zip file, the code is below:
//Beginning
#include <Stepper.h>
// change this to the number of steps on your motor
#define STEPS 200
// create an instance of the stepper class, specifying
// the number of steps of the motor and the pins it's
// attached to
Stepper stepperX(STEPS, 6, 7, 8, 9); //x (top) platform
Stepper stepperY(STEPS, 2, 3, 4, 5); //y (bottom) platform
Stepper stepperZ(STEPS, 10, 11, 12, 13); //z pen
int x_inc = 0;
int y_inc = 0;
int z_pos = 0;
word image[16] = {
0b0000001110000000,
0b0010011111000100,
0b0010001110000100,
0b0010000100000100,
0b0011111111111100,
0b0000011111000000,
0b0000011111000000,
0b0000001110000000,
0b0000011111000000,
0b0000011111000000,
0b0000110001100000,
0b0001100000110000,
0b0001100000110000,
0b0011100000111000,
0b0011100000111000,
0b1111111111111111
void setup()
// set the speed of the motors to 60 RPMs
stepperX.setSpeed(60); //bottom (60rpm)
stepperY.setSpeed(60); //top (60rpm)
stepperZ.setSpeed(60); //Pen (60rpm);
delay(2000);
void loop()
for(int row = 0; row < 16; row++) {
penUp();
stepperX.step(-x_inc);
x_inc = 0;
for(int column = 0; column < 16; column++){
boolean pixel = bitRead(image[row],column);
if(pixel == 1){
penDown();
//move X-Axis forward 5 steps for each bit in the array
stepperX.step(10);
x_inc = x_inc + 10;
delay(15);
else{
penUp();
stepperX.step(10);
x_inc = x_inc + 10;
delay(15);
penUp();
//Position Y-Axis for next row
stepperY.step(10);
y_inc = y_inc + 10;
delay(15);
penUp();
//Return X/Y-Axis back to home position
stepperY.step(-y_inc);
//Endless Loop
while(1){
void penDown()
//if the pen is raised
if (z_pos == 0){
//move the pen to the paper
stepperZ.step(83);
delay(15);
z_pos = 83;
void penUp()
//if the pen against the paper
if(z_pos == 83){
//move pen away from paper
stepperZ.step(-83);
delay(15);
z_pos = 0;
//END
//Beginning
#define STEPS 200
// attached to
int x_inc = 0;
int y_inc = 0;
int z_pos = 0;
word image[16] = {
0b0000001110000000,
0b0010011111000100,
0b0010001110000100,
0b0010000100000100,
0b0011111111111100,
0b0000011111000000,
0b0000011111000000,
0b0000001110000000,
0b0000011111000000,
0b0000011111000000,
0b0000110001100000,
0b0001100000110000,
0b0001100000110000,
0b0011100000111000,
0b0011100000111000,
0b1111111111111111
void setup()
delay(2000);
void loop()
penUp();
x_inc = 0;
if(pixel == 1){
penDown();
stepperX.step(10);
x_inc = x_inc + 10;
delay(15);
else{
penUp();
stepperX.step(10);
x_inc = x_inc + 10;
delay(15);
penUp();
stepperY.step(10);
y_inc = y_inc + 10;
delay(15);
penUp();
//Endless Loop
while(1){
void penDown()
if (z_pos == 0){
stepperZ.step(83);
delay(15);
z_pos = 83;
void penUp()
if(z_pos == 83){
stepperZ.step(-83);
delay(15);
z_pos = 0;
//END
66 Comments
mohammad-arar 9 years ago
here is my version :D
mohameds396 7 years ago
what is the code the you use
mkarim5 7 years ago
How can i use gcode ...u dont mansion this
davidhend 7 years ago
For this project I did not use Gcode to create the image; instead program draws from binary data.
There are pen plotter on instructables that do use gcode though, you can search their site for "gcode + plotter" and will find lots of examples. Have fun & good luck.
BenjaminM71 8 years ago
I'm currently trying to build your project, but I don't have 3 stepmotors. I've therefore been trying to use a servomotor in the z-axis, but it doesn't seem to work..
I have replaced the stepperZ with 'Servo servoZ;' and set the position to 0 and defined it as 'servoZ.attach(8);' in the void setup.
During the loop, I have edited the Pen Up and down to the following:
void penDown()
if (z_pos == 0){
servo.write(20);
delay(15);
z_pos = 20;
void penUp()
if(z_pos == 20){
servo.write(-20);
delay(15);
z_pos = 0;
Do you know what I've been doing wrong?
davidhend 8 years ago
The first thing that comes to mind is the pin you connected the servo to. From my understanding you will need to connect the servo to a "PWM" (pulse-width-modulation) capable pin. On a Arduino UNO those pins are, 3,5,6,9,10,11.
With that in mind, you could modify the following line: 'servoZ.attach(8);' to
'servoZ.attach(9);' and connect your servo to Pin 9. Good luck.
RenatoS5 9 years ago
Is it possible to use this for 3d printing?
davidhend 9 years ago
Maybe; I would think the hardest part would be the software. On the hardware side of things you could replace the pen with a glue gun heat element. I can't imagine that the prints will be all that good; but it might be fun to play with regardless. Have fun and good luck.
I'll try and post the results.
JacobK1 9 years ago
Great project, I am just a little confused on how your capacitors are connected in the circuit. I am actually building it right now and I have found that the caps are necessary for the motors to run properly. If you could give a guy a hand and explain how you they go into the circuit that would be awesome?
INVENTORMOHAMED 9 years ago
from where can i download the steps sorry im new in this site :)
larocca 9 years ago
Here my version:
https://www.facebook.com/video.php?v=10152419138433225&l=4664614081476599468
amorgan18 9 years ago
Olá, como faço para criar outros códigos para gerar outras imagens, algum programa que converta imagens em códigos binários, ou algo do tipo, Obrigado...
No código de exemplo, eu inseridos manualmente os dados binários para fazer a imagem . Você pode fazer o mesmo se quiser, eu não olhei para ver se o seu é um programa para automatizar a tarefa ; pode valer a pena uma pesquisa. Boa sorte e se divertir.
agentjenks 9 years ago
Hi, cool project! One thing that confuses me is whether or not the power supply has to be very high current as well? I found two little phone charger type things, both 5v, and one is around 500mA and the other was 1200mA, but I know that computer power supplies produce a much higher current. If each motor requires around 400mA, will the 1200mA work? Thanks
Thanks, I appreciate it : ) I would think you could get away with using the 1200mA 5V supply. You should check the power supply every once and a while to make sure it is staying cool; warm to the touch is okay but hot is not.
Thanks!
zextron 9 years ago
Here is mine! Thanks for sharing!
http://youtu.be/70jekaZHsSQ
gmoenik 9 years ago
Next Step GCode.. rsrsrs!..
