Introduction: Cheap Car Seat Office Chair!!!
Build a unique piece of furniture and recycle in the process!
I got the idea for this project after watching old seasons of "Top Gear". In the studio, the show hosts sit on seats taken from an old car, and recycled into living room furniture.
For my project, I wanted a unique office chair built from a car seat that could recline and rolls around like this example HERE.
Since I was a poor college student, I couldn't afford a $680 office chair, and instead set a budget of $40.
Total Cost:
- Chair - $25
- Base - $10
- Hardware - $3
- Plywood - free! (I already had it)
$38!
The rest of the pages describe the steps I took to find the parts and build the chair. Enjoy and good luck!
Step 1: Find a Seat.
- Although the seat might look great in the car, keep in mind that its new home will be completely out of its element, presumably in a house, so make sure that the chair wouldn't look hopelessly dated in your home. (For example: A '67 Mustang chair might be pretty sweet in a Mustang, it might not look so good with your wife's Ikea furniture.) It's just something to consider.
- Make sure your seat has a mostly square bolt hole pattern, and that all the bolt holes face straight down. If your brackets are asymmetrical, or angled (or, God forbid, both) you'll just be adding that much more complexity to the project. I was lucky enough to find a seat with mostly symmetrical bolt holes, making my base pretty easy to cut.
- Try to avoid electric seats. If you want to able to use the chair's built in adjustment controls, it's much easier to pick a chair with manual controls. You might be able to wire up a system to power an electric seat, but that's out of the scope of this instructable. Sorry.
Now that you know what to look for, where do you actually get a seat? Here's some ideas:
- Ebay or Craigslist - These probably won't have the cheapest seats, but they will have the best selection, and you're not going to have to pull it from the car yourself. Keep in mind, though, that some cleaning will probably be required, unless the seat is brand new.
- Auto parts stores - This will be the most expensive option, but if you really want a SPARCO race seat, or don't want to bother with used seats, you'll mostly like find one here.
- Dig one up yourself at an auto recycling lot (like U-Pull-It, or something similar) - This is going to be your cheapest bet, and the option I chose. Bring a tool kit with a decent socket set, pay a small entrance fee (usually about $2) and start looking! You will have to look hard. The lots are huge, but most vehicles have been sitting there a while, and the seats are likely to be moldy, torn, and/or pretty dirty. After 2 hours of searching, my brother and I found this leather seat from a newer Infiniti that hadn't been beat up, ripped, or otherwise defiled. The company charges for seats based on features, not condition. Since my seat only had manual controls, it was just $24.99! What a steal!
Step 2: Find a Base.
- Like the seat, a simple bolt pattern and a flat top will make your life much easier.
- Check to make sure the controls still work, if you want to use them, and that none of the components are rusted out, as that's just not safe.
- It's unlikely that you'll be able to get just a base like I did. (I got really lucky there.) So make sure you can easily remove the office chair from the base, and that the chair arms aren't directly attached to the base. Make sure you have a way to dispose of the old chair before you buy it!
Step 3: Build and Assemble the Base Plate.
Now that you have the key components, start making your base plate. I used 3/4" plywood for my base. This is the thinnest you should go!
Set your seat down on the plywood, and measure the smallest possible square for the chair to sit on. You'll want to leave a bit of room around the bolt holes of the chair, in order to maintain the plywood's strength.
Use a circular saw to cut out your plate, then center it on the base. Set the chair on the plate, and mock up your seat before you start drilling bolt holes. Make sure the plate places the seat on the base in a comfortable position, and that the chair is more or less level.
NOW you can drill. Mark the positions of the bolt holes for both the base and the seat and drill them out. (It might be easier to completely mount the plate to the base, then do the chair.)
Hardware: I used four 1/4" diameter bolts for the base, and four 5/8" bolts for the seat. All the bolts were 1.5" long. These are just for reference, as your chair and base will undoubtedly vary from mine.
Make sure to use washers between the bolts and the wood. The wood will experience quite a bit of force when you recline, so spread out the load wherever possible.
Step 4: Finish.
- Paint the base. (Black will probably be your best bet.)
- Clean your seat, if dirty. I used leather conditioner and leather cleaner to wipe away the dirt smudges. A good vacuum job took care of all the crumbs tucked away in the cracks.
- If you kept the seat belt, staple it underneath the base and buckle it in! Although you probably won't want to do this all the time, it's just one more conversation piece on an already unique chair.
The Instructables Book Contest
38 Comments
6 years ago
DIY Heated Office Chair
6 years ago
7 years ago
I just thought of this last night and stumbled onto this site while looking for info. Seems easy enough but the thing that concerns me is that plywood base, wouldn't metal or something work better? With daily use I envision that wood cracking.
Reply 7 years ago
Well, that depends on what type of seat you get. A high-riding seat from a van or pickup might be a problem, but I made this chair 8 years ago, and the only problem I had was with the base casters wearing out. the plywood has held just fine, and the chair has survived 4 moves since then, and still works great.
I will probably retire the current chair base at some point and rebuilt it into a more stationary chair, but for now, it's still going strong 8 years later in the same form I built it in. :)
7 years ago
I have been looking at used computer chairs and they all have poor cushion material, even the new ones are hard and uncomfortable but a car seat you can drive for hours in comfort. Makes sense to use one. Good instruct-able. I will be making a video of the assembly on youtube in the near future.
8 years ago on Introduction
Oh nevermind, sillly me, I found it :D
Always wanted to make something like this. Standard office chairs are nowhere nearly as comfortable as car seats when it comes to prolonged times on a desk. Did I miss the step-by-step process, how was it made exactly?
9 years ago on Introduction
I did this with a VW Jetta leather seat. It turned out great except my feet don't touch the floor. Turns out the with of the butt cushin is a lot thicker on the VW seat than the office chair was. Did anyone else have this hiccup or did I just pick a bad seat for this mod?
BTW, I was able to re-use the plywood from the old chair and it fit real nice to the underside of the seat. Almost looks factory
10 years ago on Introduction
Oops, just published a similar instructable. But yours is way more complete. Kudos!
Did you just center the Base or had to play with it to avoid falling/backflip. I am planning to leave some plywood for a cupholder, remote control, magazines and/or munchies holder. That way no one will comment about the extra plywood protruding from the chair. And since it is for my personal use, who cares what other will think. Great job
11 years ago on Introduction
Lol, i should have known the idea was from top gear. Well, i think i know how to keep the memory of my alfa 164.
The plywood should have rounded corners and should be spray painted black also if you go to a fabric store and select lets say a silverish quilted fabric then get in touch with a seamstress you can cover it pimping up the look , the same applies to a backseat , remember that the back seat should be straight balanced using 2, 2x4 blocks placed in the back legs of the 2 seater or else you would be seating in a leaned back awkward position..
Reply 11 years ago on Introduction
If you look at the end, I actually did paint the base black. It fades away from your view now, so you can't really see that it was mostly hacked together (ie. rounding the corners is not really necessary).
I got a leather seat on purpose, because that is what I wanted to sit in, but reupholstery is certainly an option if you're having a hard time finding a seat without split seams or tears.
As for the back seats, well that depends on the vehicle. Most van seats for example sit flat, so rear supports are not necessary, but I see what you're saying. Actually, most rear sedan seats will not work since they are simply foam moldings that use the car's unibody for support. Once you remove them, they are not able to support a person from their own structure. My WRX has seats like this.
Easy to do, functional, looks pretty decent, and "why didn't I think of that" -- nicely done. (Closest I've gotten has been using my van seats as porch furniture when they're unmounted, and I really should make some snap-on feet for them.)
Good job -- you beat me to it.
My chair is broken, but the base is still good. Must find a car seat.
hehehe awesome high five for you!
11 years ago on Step 4
Actually, it's also a conversion piece.
12 years ago on Introduction
Thanks! I've wanted one of these for a long time. I talked a friend out of an office chair with a broken back and got a nice car seat from the local Pick N Pull. The office chair had a plywood bottom inside all the foam and stuff. It's a little curved, but it worked fine.
Some pics:
https://plus.google.com/photos/102464241338364347663/albums/5656030360238008129
12 years ago on Step 4
I think you mean to say "conversation piece".
