Cheap Drill Press DIY
Intro: Cheap Drill Press DIY
I decided to build a drill press for 12$.
I have mostly used design by Izzy Swan he have pretty good build videos: His YouTube Channel
Here You can see the video of my final product : https://youtu.be/Ogf9JVEOmrY
Now I can drill bunch of 90deg holes.. but why?
Thank you,
STEP 1: Materials and Tools
Materials:
1.Use your old corded drill or buy the cheapest one:
Example HF coupon for 12$ Drill: coupon
2. hose clamp
3. Scrap wood
4. Wood Screws
Tools
1.Table Saw (Can be done with a any saw, but have to changed little bit).
2. Drill.
3.Safety Glasses.
STEP 2: Aseembly
Create a slide by sandwiching wood pieces together.
Use paper as a shims between the wood.
Wax the sliding surfaces.
STEP 3: Assebbly
Secure the drill into the sliding carriage.
Take a square and make sure that the drill bit is 90deg to the surface. Use wedges if needed.
Add Handle and a spring to allow better pushing and returning.
7 Comments
kukopia 6 years ago
All to vague to be of any use
Yomismo62 8 years ago
Hello you can clarify complementing your project, such as holding the drill. Since in all three phases you have here, no clarifies
sagariwa 8 years ago
thanks. you've been very helpful with your photos and description plus the link to the video. til the next project then.
Elliot Lord 8 years ago
It looks good but there aren't any real instructions to follow and it looks quite complicated.
handroid7 8 years ago
Thank you,
The reals instructions are:
You need to take a look at your drill..make a holder for it.
You need to buy/make sliding mechanism.
Attach them together :)
Its pretty easy to make.. hard part is to alight it and also make it stable.
seamster 8 years ago
This looks pretty slick. Nice work!
Thank you,
Its not as good a store bough drill press .. but than i good enough .:)
