Cheap Portable Projector Screen
Intro: Cheap Portable Projector Screen
I finally decided to upgrade from the sheet I had tacked to my wall. I had a small budget, and wanted to be able to take it down when I wasn't using it and this is what I came up with.
STEP 1: Materials
I already had some of the materials, so it cost me less than a dollar, but it could be done for around ten bucks.
You need:
-An old sheet.
I'm sure you could find a cheap one at walmart or goodwill or something.
-PVC.
I got twelve feet at home depot for 75 cents, they even cut it for me.
-Eyelets/ eyelet kit
If you don't already have one, they have the kit at home depot for a couple dollars.
-Hooks
The kind with the little screw on one end.
That's about it. I also picked up a pack of velcro straps at walmart for 2 dollars. I needed them anyway for cord management.
You need:
-An old sheet.
-PVC.
-Hooks
STEP 2: Construction
1. Decide what size you want. Mine is 5 feet wide by 6 feet tall.
2. Cut and sew the top and sides. Leave a couple inches extra on each side so you can fold it over and sew a seam.
3. Insert eyelets. One on each side of the top.
4. Sew in pvc pipe. This is to make it hang flat and straight, and to make it easy to roll up and store. Just fold the bottom over the pvc, crease the sheet, take out the pipe and sew all the way across. Then slide the pipe in and sew the sides shut.
5. Put the hooks in your ceiling. I put some in my living room, my bedroom, and another bedroom. They're hardly noticeable so I just leave them up there all the time.
STEP 3: Enjoy
Hang it up and enjoy. Whenever you're not using it, just start at the bottom and roll it up, then put the velcro straps around it and put it in a closet or something. As always, thanks for reading.
Sidenote:
I thought about cutting the pvc in half and leaving about a two inch gap in the middle so it could be rolled up and folded in half. Whatever works for you.
Sidenote:
16 Comments
imsokoool 8 years ago
um.......sounds good but is there an easier way to do the screen?
kiddutch 13 years ago
cojo88 14 years ago
SoulvilleUSA 14 years ago
jdtwelve12 14 years ago
TimBTodd 14 years ago
Mud Stuffin 14 years ago
paulschroeder90 14 years ago
lsmith254 14 years ago
frollard 14 years ago
Picked it up at a fabric store (its designed to make drapes)
http://www.amazon.com/Black-Out-br-Drapery-Lining/dp/B000WFP8V4/ref=pd_sbs_k_2
My friend, with whom i built this, actually picked it up for me, so I'm not sure where he got it. I want to say michaels or bed bath and beyond. It cost less then $10 because it was bulk fabric, but I can't seem to find anything like that on their websites, but this site seems to have some that is affordable.
omnibot 14 years ago
I'd like to add the following improvements:
.. another bar to stiffen up the top to reduce drooping
.. black edges for sharper contrast, matt ducttape should do the trick
spacepirate04 14 years ago
