Introduction: Cheap and Easy Passive Solar Water Heater for Your Home. ($300)
Heat your water for free with a solar water heater. This $300 DIY solar water heater system even includes an electric backup water heater for cloudy days. It heats water to 135F (55C) on sunny days in a 80 gallon (310 liter) tank - and there are no moving parts - it relies in a thermosyphon to circulate the water.
http://www.myfixlog.com/fix.php?fid=1
This heater uses PVC instead of copper. PVC has a much lower thermal conductivity than PVC does, however there are a few ways to over come this weakness.
One way to I increased the efficiency was to use old florescent light bulbs as sleeves over the PVC pipe to act as a double glazing. This helps insulate the PVC and increases the efficiency of the heater. I also insulated the PVC connections to help shield them from the intense heat of sunlight.
The other way I increased efficient was increasing the surface area. Since PVC is cheap it did not cost much to run more pipes that would be exposed to the sun.
I also installed an automatic electric backup heater for $30. It is a bucket heater that turns on at 80 degrees and off at 110. Click on the link above to see more about that.
