Kerosene to Propane Generator Conversion-Cheap and Easy
Intro: Kerosene to Propane Generator Conversion-Cheap and Easy
I have yamaha kerosene generator since kerosene is hardly to get, so I experimenting to use gas (propane). And it works.
It don't need any changes on the carburator so if there is no propane gas, I can still use kerosene or gasoline.
And it only cost around $15.
STEP 1: What We Need
for this convertion we only need 3 main component.
- high pressure gas regulator
- gas hose
- gas valve (like the one in the picture)
tool: only drill
- gas hose
tool: only drill
STEP 2: Set Up the Position for Gas Valve
The gas valve will be place aline with the carburator.
STEP 3: Now Use Our Drill
Use our drill to make a hole at the air filter cover and air filter honeycomb.
STEP 4: Cut the Valve Pipe
use iron saw to cut the pipe on the gas valve, to adjust (if it necessary)
STEP 5: Put It Back in Order
Now we can put it back in order.
STEP 6: Start You Engine
It will need some feelings to start the engine.
We have to open the gas valve slowly so it will give the right mount of gas.
After it start, try to open and close the gas valve to get engine stationary stage.
WARNING
Always run the generator on open air or in good ventilation.
The gas will not automatically shutdown when the engine stop running.
Have a nice experiment.
Good luck.
WARNING
Good luck.
24 Comments
nutgone 9 years ago
Without a proper, vacuum operated, on-demand engine regulator this is dangerous. Please, if you plan on making this conversion, do it properly or face the consequences. You can even make your own on-demand regulator by converting an old fashioned standard regulator (it needs to be the type you can take apart), there's plenty of info on line, but please, don't just use a standard gas appliance regulator, unless you have a death wish & like blowing things up.
hendrosutono 9 years ago
We just tried to utilize what we have most. Just like many inventors before us. They who dare taking the risk of death to make better life.
We still live in 19 century where there is no insurance company saying it's not safe and not covered. Even our goverment can't provide us with our basic needs. Electricity is never stable thing, sometimes on - plenty off. We can't buy gasoline in jerrycan.
but thank you for your concerns.
I still looking to improve my system. If you have know how to built simple solenoid, I will be very happy.
best regards
nutgone 9 years ago
I will have a google & see what I can turn up, I'm not sure I will be able to post links in these comments, but I could at least give you some keywords to search for.
Basically, an on-demand gas regulator works in the reverse of a normal one. If you can find an old fuel gas regulator which you can take apart (one with little screws or bolts holding it together) you can dismantle it & mount the spring on the reverse side of the diaphragm (at least I think that's how it's done, I would urge you to double check that first). This would also save you a lot of fuel & would mean when the engine stops, the flow of gas stops too.
They can also be found on old engines which were equipped to run off gas. Sometimes these are found in scrap yards, some old military units had these supplied too, as a back-up source of fuel, & many would never have been used & could well have been scrapped with other old surplus.
but then I have to make a hole at intake to get the low pressure that needed to open the valve.
my target is to make modification as simple as it can be.
Then there is common rules that we can only turn on the generator at open space or outdoor. And never leave running generator unattended.
ddudette 10 years ago
I was really on the verge of giving up on deciding about using propane conversions but I think somehow I found the answer. I am a newbie here but I would just like to share my experience since some people might feel the same way. At first I was a bit doubtful if converting gas to propane would really fit my expectations but I've come to realized that yes, it is the answer for my longing prayers. It's very affordable, convenient and is truly a lifesaver. I don't need to spend too much on gasoline and I enjoy the perks of saving my precious time and energy. Just to share, try visiting this website that I found,http://gomowpropane.com/conversion-plans/. It's a good reference for your concerns about propane conversions.
I hope it will help you like it did for me. :)
londobali 11 years ago
Hey, i never knew it was that easy and cheap!
Only in this setting you need to take care and remember to turn off the gas supply when the engine is off..
This guy installed a solenoid to turn off the gas flow when engine shuts off:
https://www.instructables.com/id/DIY-natural-gas-generator-convertir-de-nafta-a-ga/
Do you know how the car-conversion works? it would have some sort of flow control synced with the throttle control of the engine, i suppose?
Great job! keep em coming.. :)
Thanks for sharing!!
"Tarik choke sampai stabil"... lol... salam dari Bali Mas!... :D
hendrosutono 11 years ago
yes it's not totally save... but that is the price we have to pay... if we can't get the proper equipment or don't have money to buy parts we needs, we have to pay by doing more afford and hard works. In this case we have to always pay attention when the generator is running... it's not a problem for me cause usually power outages only run for 1-2 hours( I live in Jakarta) and only 2-3 times a year.
yes, the main problem on car conversion is throttle control... the system is more complicated it will need solenoid valve, engine management computer, air flow controller, etc... It's too complicated for me... just leave it to the professionals... hehehe...
Just remember to tell the wife and anybody in the house to swich the LPG off in case the genset dies.. :)
i lived in Balikpapan for four years, we had PLN cutoffs everyday there.
I'm not kidding: everyday for three hours!!
Anyway, I'm familiar with the noise of the genset on the porch..
Also the problem of refueling: They dont allow people to buy gasoline with jerrycans in Balikpapan (meant to stop the illegal street vendors), so i had to buy gas to my motorbike then transfer to the genset..
If i had known your trick back then, it would have been much easier.. I would have done it exactly like you did, no need for solenoid too.. :D
But for those who have a bit more money to spend, a solenoid would still be recommended..
asafche 13 years ago
it's great.
can it work on methane gas (organic waste gas) to? the major problem that it is uncompressed, i think...
what are your recommendations?
thanks.
asaf.
But I think it's more simple if we use methane to light up fire. the fire is used to boiled up water, then the steam is used to spint a turbin connected to dynamo... or like a steam locomotive...
or make a stirling engine like https://www.instructables.com/id/Walking-Beam-Stirling-engine/ - then we use the up an down movement to move coil from a shaker flashlight
or use peltier concept like https://www.instructables.com/id/How-to-build-a-thermoelectric-lamp/
both of stirling and peltier can use methane to light up the fire they needed.
although i was wondering(since you pop-up the question) is it possible if we use air pump that usually used on aquarium to pressure up the methane... or using pump that used to fill up air mattress... :-)
but those pump need electricity to run.... :-p
Rainh2o 14 years ago
hendrosutono 14 years ago
It came with kerosene when we buy it. But it still need gasoline for starting. So there is two tank, gasoline and kerosene. when starting up, we got to pull a valve on the carbs, it will let gasoline flowing to the carbs reservoir, so gasoline and kerosene will mix. After the engine heated up only kerosene will flow to the chamber. I think kerosene need to be heated up first before easily to burn, just like diesel fuel. In diesel engine there is one part who preheat the fuel before we start up.
Maybe you can modified your gasoline engine by adding a smaller tank to fill with gasoline and the big tank(the one you already got) fill with kerosene. Then you need a switching valve. So after your engine is starting and heat up by gasoline you can switch to kerosene.
Another idea I have is by following kerosene to copper pipe that coil the exhaust pipe. That way the heat from exhaust pipe will preheat kerosene before entering carbs. But it still need gasoline to start then after heat up we can switch to kerosene. I think by doing this innovation we will save same fuel, because the burning will be more efficient.
Have a nice experiment.......
Please let me know which way is works.....
kill-a-watt 14 years ago
gas is 115000 BTU/gallon
K1 is 135,000 Btu per gallon but probably costs more in your area in the amount of BTUs per dollar.
I've never fooled with it but I suggest you start by taking the lawn mower engine and reducing the compression somehow. Once I read that one way to go about that would be to use two head gaskets. This should be a fairly easy conversion if the old lawn mower engine is not overhead valve and is air cooled (most are)
It's also true that today kerosene is more expensive even in my country(indonesia).
As you now lately indonesia hit by several earthquake. My main objective is to make a generator that can use any fuel we can get in case of emergency.
If I'm not mistaken more calories contains in fuel, less compression we need. Therefore if we want to use kerosene for gasoline engine, we must adding the compression.
http://www.engineeringtoolbox.com/fuels-higher-calorific-values-d_169.html
My personal challenge is how we can improve the generator to use many different type of fuel without any major changes and switching between fuel at any time instantly.
Now I'm thinking about how making my generator runs using cooking oil...
any suggestion?
chaydgb 12 years ago
You write pretty good English to be from Indonesia.
I got this link from friend of mine...
http://www.youtube.com/watch?v=F258s13UxfY&feature=related
you are so lucky to have a back yard full of trees... I live in urban area so I can only depend on fossil fuel... :-(
Beside experimenting with cooking oil, I'm starting to experimenting with Peltier thermoelectric. If it works we can produce electricity direct from the heat. Heat from the sun or from the stove or chimney...
Maybe this website can gift you more clear picture...
http://www.dself.dsl.pipex.com/MUSEUM/POWER/thermoelectric/thermoelectric.htm
The modern module is more simple, but the retro concept also likely to applied.
Maybe it's not much produce power but it is from wasted heat... so we have nothing to lose... :-)
These machines were invented because gasoline was taxed at a higher rate for road revenue purposes.
About a decade ago, here in the US, something was manipulated such that even without the road tax, kerosene was as expensive as diesel. Truck drivers promptly stopped running their rigs on 50/50 mix of diesel and undyed kerosene (or so I hear).
You can get a spark ignited internal combustion engine to run on kerosene by designing it with a low compression ratio and making sure you can somehow warm it up before you switch over to kerosene.
