Cheapest Arduino || Smallest Arduino || Arduino Pro Mini || Programming || Arduino Neno
Intro: Cheapest Arduino || Smallest Arduino || Arduino Pro Mini || Programming || Arduino Neno
Please SUBSCRIBE To my YouTube channel for more videos........
This project is about how to interface a smallest and cheapest arduino ever.
The smallest and cheapest arduino is arduino pro mini.
It similar to arduino Uno but it is small and cheap as compare to arduino Uno.
STEP 1: Requirements
- Arduino pro mini
- Arduino Uno
- Connection wire
- 9v battery
- Led
STEP 2: Prepare Arduino Uno
- Remove Microcontroller from arduino uno
- Connect connectors to arduino pro mini
STEP 3: Connections
Arduino pro mini - - - - > Arduino Uno
- DTR/GRN - - - - - - - > RESET
- TX - - - - - - - > TX
- RX - - - -- - -> RX
- 5V -- - - - - - > 5V
- GND ------------> GND
STEP 4: Connection of Led
- Positive terminal of led - - - > 9th pin of arduino pro mini
- Negative of led - - - > GND of arduino pro mini
STEP 5: Upload Program
- Connect your arduino Uno to pc
- Open tool >> port select port where your arduino is connected
- Open tool >> board >> select arduino pro mini
- Open tool >> processor >> select as your board. If you don't know your arduino's processor then try each
- Open file >> example >> basic >>fade
- Upload this program to arduino
STEP 6: Connect 9v Battery
- Positive terminal of 9v battery - - - - > RAW pin of arduino
- Negative terminal of battery - - - - > GND pin of arduino
All done..............
8 Comments
russ_hensel 6 years ago
https://www.google.com/search?q=Arduino+pro+mini&safe=off&client=opera&hs=w7O&sa=X&tbm=shop&tbs=p_ord:p&ei=UV94WuPNGcet0gKqs4rwBw&ved=0ahUKEwijusDj847ZAhXHllQKHaqZAn4Quw0I7AQoAg
and
https://www.google.com/search?q=arduino+nano&safe=off&client=opera&hs=5S4&sa=X&biw=1680&bih=845&tbm=shop&tbs=p_ord:p&ei=cl94WvmzN-mL0wLRpZvACQ&ved=0ahUKEwj5tLzz847ZAhXpxVQKHdHSBpgQuw0I5gQoAQ
I have bought some of the very inexpensive ones and so far so good. USB has been fine.
vishalsoniindia 4 years ago
here 3 arduino pro mini in aprox 9$ so each of 3$ .... i think this is cheap then your 9$ usb arduino.
carlos66ba 6 years ago
vishalsoniindia 6 years ago
I have found arduino pro micro is about 8$
But arduino pro mini is about 6$
xxxCHICAGOxxx 6 years ago
Harsh Dethe 6 years ago
