Cheese Egg Toast
90,355
627
46
Introduction: Cheese Egg Toast
About: I am a student at UT Austin. I love to cook and I have a YouTube cooking channel: https://www.youtube.com/c/jonathanmalott
I recently saw a recipe on Crazy Adventures in Parenting for a baked egg toast with cheese. I tried it and loved it, so I've made a tutorial for you guys along with a how-to video.
Step 1: Gather Your Ingredients
First, preheat your oven to 350 degrees Fahrenheit.
Next gather up your ingredients:
  1. Sliced bread, a bit thicker than normal sandwhich bread.
  2. Cheese (i'm using a blend of four mexican cheeses, i believe)
  3. Room temperature eggs, the same number as the number of bread slices you have
  4. A small bit of butter or vegetable oil
That's all you need! If your eggs aren't at room temperature, put them in warm but not scalding water for about 5 minutes, or they won't cook in time.
Step 2: Create Space for the Eggs
Place your bread on a half sheet pan or cookie sheet.
Using a spoon, create a square indentation in the middle of the bread (see picture). Use the tip of your spoon to create the edges, and the back of the spoon to push down the middle.
Next, using a brush, brush on some oil around the rim of the bread. This will create good adhesion for the cheese.
Step 3: Add Cheese and Eggs
Sprinkle the oiled rim of the bread with cheese. Try to be careful and not get cheese on the baking sheet, because it will definitely burn.
Finally, crack an egg into the middle of the bread slices.
Step 4: Bake
Place the cookie sheet into the middle of your 350 degree oven and bake for 8-10 minutes, or until the egg is just barely runny.
In this particular recipe, I have found that the egg always comes out a bit runny. If you keep the toast on too long it will burn before the egg is completely firm. I like them runny, so this is perfect for me.
Step 5: Serve to a Greatful Audience
After removing from the oven, season and serve your lovely baked egg cheese toast. This is a very easy meal to make, and consider how good it tastes, I will be making it very often.
You can check out my YouTube channel here, I post new cooking videos every friday:
www.youtube.com/c/JonathanMalott
4 People Made This Project!
  • Plywood Contest
    Plywood Contest
  • Halloween Contest
    Halloween Contest
  • Microcontroller Contest
46 Comments
Blue Hawaii
Blue Hawaii
7 years ago
I like this variation on "eggs in a window" or whatever everyone else calls this dish. I like how you made an indentation in the bread instead of how I use a cookie cutter to make the "window". I will give this a go. Thanks.
mduncan8
mduncan8
I have always heard that called eggs in a basket.
JonathanMalott
JonathanMalott
Reply 7 years ago
Thank you very much! I thought about using a cookie cutter too but didn't have the right sized one, so this worked out perfectly for me!
Snidely70448
Snidely70448
A glass or shot glass works, either to depress the bread or cut a hole.
VeronicaT
VeronicaT
Thank you for sharing. I'm gonna try them. I'll use some parchment paper to make clean up easier :)
I legitimately just made these, my good they tasted so good, but for my oven I think I need to do 6-7 minutes for nicely runny eggs
mduncan8
mduncan8
I made this but with my toaster oven... I found the eggs kind of hard or rubbery...
ebernal3
ebernal3
7 years ago
I had some trouble keeping the Eggs in boundaries, but I think the slices might have been too thin. Otherwise, a great and simple dish
JonathanMalott
JonathanMalott
Reply 7 years ago
Thank you! I found that texas toast is thick enough to hold the egg.
wertyleigh
wertyleigh
7 years ago
I think everyone has grown up with a variation of this in one form or another. Myself, Eggy in a basket. The baking and cheese sound like a great upgrade though. although I do wonder if Black sauce on the bread before the cheese would make it better, or a very, very thin spread of marmite..... just a thought...
Brett Beedrill
Brett Beedrill
I experimented with something like this a few months ago. I put a hole in it instead of depressing it, and used butter to fry the egg inside. I found putting cheese before the egg made a nice crispy underside.
MichaelAtOz
MichaelAtOz
Needs bacon. Every thing needs more bacon. Diced and sprinkled on top I think, yummmm...
TexasD
TexasD
We grew up calling them "egg in a basket" and they were fried. This sounds great and also is healthier for us.
