Cheesy Football Dip
Intro: Cheesy Football Dip
This cheesy chip dip is so rich it doesn't take much to fill you up! Despite that our friends always devour the whole pot every time we have a party. This is my mother-in-law's recipe that they used to make while watching football games in the fall. It's the perfect warm and filling snack.
STEP 1: Tools and Ingredients
You will need:
- 1 lb of ground beef
- 1 lb of ground breakfast sausage
- 1 box of Velveeta cheese
- 1 can of Rotel tomatoes
- 1 can of cream of mushroom soup
- chips (one pot usually takes two bags of scoops)
- spatula
- serving spoon
- crock pot
- skillet
- knife or scissors
- can opener
STEP 2: Drain the Tomatoes
Use the can opener to partially open the lid to the Rotel tomatoes. You don't want it open enough that the tomatoes can fall out yet. Pour the liquid out of the can, you can set the can upside down in the sink and let it drain while you work on the next two steps if you choose.
STEP 3: Add the Soup
Open the cream of mushroom soup and add it to the crock pot. You may need the spatula to get it all out of the can. It's important that the soup is on the bottom because it will heat quickly and help to melt the cheese.
STEP 4: Add the Cheese
Open the Velveeta cheese and cut it into chunks so that it will melt faster and add them to the crock pot in an even layer.
STEP 5: Add the Tomatoes
Open the tomatoes the rest of the way and pour them into the crock pot. Use the spatula to distribute them across the surface so they don't create a cold pocket.
Once finished set the crock pot to the low setting for 4 hours. (It will not take this long to cook, but it's the shortest time on ours.) Put the lid on and let sit while you prep the meat.
STEP 6: Brown the Meat
Place the sausage and beef in the skillet and brown on medium high heat. On our oven it's a 6 out of 10.
Use the spatula while browning to cut and stir the meat into small pieces so it will spread easily throughout the dip. It's ok if there's still a little bit of pink left like in the last picture, it will cook out in the crock pot.
STEP 7: Drain and Add the Meat
We don't want all the grease in the dip because it will be runny. Take the spatula (or you could use a pot lid if you need more assistance) and pack the meat down a bit so you can pour out the majority of the grease. You can dab the rest out with some paper towels to avoid spilling the meat if you choose.
Then add the meat evenly over the top of the cheese mix in the crock pot and stir it in. The hot meat will help to melt the cheese.
STEP 8: Cover and Wait
Once all the ingredients are in the crock pot put the lid back on. It will need to be stirred every 15 minutes or so until the mixture is a homogeneous texture. (It takes approximately an hour.) Make sure there are no chunks of Velveeta left in the pot like in the last photo.
Once the dip is finished you can turn the crock pot off. Or set it to warm if you need it to be out for a while during a party or game.
STEP 9: Time to Party
Use a serving spoon to scoop out dip onto your plate and dig in with some chips! This snack is warm and filling. Perfect for cooler fall weather. :) It will keep in the fridge for 2-3 days.
16 Comments
13AccentVA 6 years ago
Swansong 6 years ago
Thanks, let me know how it goes when you do! :) I'm not sure what water you mean. The water from the canned tomatoes? We drain that in the sink so the dip is nice and thick and sticks to the chips.
No worries! I understand now. No, we don't add any extra water in. The juice from the meat and the tomatoes is enough. You wouldn't want it to get too runny. ^.^
TechMartian 7 years ago
Looks sooooo delicious.
Swansong 7 years ago
Thanks!
JennaJMac 7 years ago
yummers!
KarenK116 7 years ago
Great instructions. Looks good and I'm going to make it this Sunday for the game
Thank you :) Let me know how it goes!
jdonato 7 years ago
rafununu 7 years ago
This issue can certainly arrive with very small tubes. I never had to call a plumber in 40 years and I poured all sort of greases in the drain, but I allways ran hot water during and after. I know this is not planet friendly, I won't do it again.
surya raju 7 years ago
Absolutely! My husband says ground turkey is a great substitute for the beef and you can use ground chicken in place of the sausage, but you may want to add salt since it will have less in it and may change the flavor.
grannyjones 7 years ago
I use a colander to separate the beef and the fat. A metal or glass pan will catch the grease to keep it out of the drain. If I want the meat even leaner, I can run hot water through it. Plenty of fat in the cheese.
ckoehler1904 7 years ago
Looks VERY tasty - thanks for posting. The only major caveat is to make sure to NEVER pour any kind of grease down the drain. My dad was a plumber for over 50 years and he made a sizable percentage of his annual earnings directly or indirectly clearing drains which were clogged by people pouring grease-containing liquids down the drain. Even if the liquids are very hot when poured, they will eventually cool as they make their way down the plumbing stack, creating an endless source of jobs for plumbers and an endless source of bills and grief for home owners. Better to drain greasy liquids into empty tin cans instead and dispose properly in the trash...or as your municipality/country recommends. Cheers and enjoy your beefy and cheesy dip!
