Introduction: Chest of Drawers From 2 by 4's
This plan makes a chest of drawers from 2 by 4s and 2 by 6s for the top. The cabinet is 22 ½ inches at the widest point, 22 inches deep and 31 inches high.
All my builds are made with pocket hole joinery. You will need a pocket hole jig tool such as a Kreg Pocket Hole Jig in order to build them.
The 2 by 4 and 2 by 6 was actually taken from an old work bench and so the dimensions were dictated to some extent by the wood I had available from that and the cuts I could make from it.
I have tried to ensure all steps are covered in these plans but if you find any errors in the plans or have a question then please email me at info@andrewharriswoodwork.com to let me know.
Step 1: Shopping List
Step 2: Cutting List
Step 3: Make the Two Side Panel Inserts
I made the inserts for the sides from 4 four pieces of 2 by 4.
Put the pocket holes on the inside and also put a pocket hole in the top and bottom of each piece to fix to the top and bottom rails.
If you prefer you can use a piece of plywood for a solid panel look instead.
Step 4: Make the Two Side Frames
Make the side frame by attaching the two 29.5 inch legs and the 14 inch 2 by 4s as the top and bottom rails.
The actual width of the 2 by 4s may not be exactly 3.5 inches and so you may need to trim the 14 inch side rails slightly once you have the insert part made.
Step 5: Add the Back Rails
Add the 2 by 4 pieces of back rail as shown.
Make sure the pocket holes are on the inside. The pocket holes should be drilled on the narrow part of each piece.
Step 6: Add the Front Rails
Add the 2 by 4 front rail pieces as shown.
I put the pocket holes for the top rail on the top so would be hidden by the top. For the bottom rail I put them underneath so they would be hidden. The pocket holes should be drilled on the narrow end part of each piece.
Step 7: Make the Top Smaller Drawer
Drill pocket holes in the both ends of the 15 ½ inch length drawer pieces.
Join the 16 inch pieces to the 15 ½ inch lengths to form the drawers.
You can either route the sides to fit ¼ inch plywood base inside or fix the base to the bottom.
Fit the drawer slides to the bottom of the drawers as well.
Step 8: Make the Two Deeper Drawers
Step 9: Fit the Drawer Slides to Frame of Cabinet
Follow the instructions of your slides to fit them to the sides of the cabinet. Usually there should end up being half an inch gap between the bottom of the drawers and top of the rail underneath it but follow the instructions that come with your drawer slides.
Step 10: Fit the Drawer Fronts
The small drawer front is the 1 by 6 piece measuring 17 ¾ inches long (1/4 inch narrower than the space they are fitting). Measure and cut to fit your project though.
The large drawer fronts are the 1 by 8 pieces measuring 17 ¾ inches long (1/4 inch narrower than the space they are fitting). Measure and cut to fit your project though.
Fit the drawer fronts ensuring equal gap at top and outer edge for both.
Drill two holes through the inner drawer front and then fix the outer drawer front by screwing through the inner drawer front into the outer drawer front using 1 ¼ inch screws.
Tip - clamp the drawer front in position when happy with the spacing and then screw it in place.
Step 11: Make the Top
Make the top from the four 2 by 6 pieces measuring 22.5 inches long (this gives a ¾ inch overlap on each side.
Step 12: Fit the Top
Drill pocket holes on the side and back panels facing upward for screwing the first top layer to with 2 ½ inch pocket hole screws.
Drill through the top of the front 2 by 4 rail so the top can be screwed on from underneath.
Place the top with the good side down and then place the upturned cabinet on top. Make sure you have equal gap all around and then fix the sides and back with 1 ¼ inch pocket hole screws and the front edge with 2.5 inch wood screws through the front rail.
Step 13: Fit the Back Panel
Fit the back panels from the inside. I suggest you leave at least half an inch gap around the edge and use ¾ inch finishing nails to fix it. Dimensions given in plan (12 inches by 17 ½ inches) allow for 1 inch overlap around each side.
Step 14: Finish
Sand well to smooth our joints and remove any wood glue residue.
Apply Pre stain and your choice of color or paint as desired. The example in these plans was finished in Varathane Carrington and Varathane Matte Poly.
Step 15: Hardware
Add hardware of your choice to the drawers (you will need to temporarily remove the front drawer parts).
Wood Contest 2016
