Chocolate Peanut Butter Bars
Intro: Chocolate Peanut Butter Bars
These are so,so good and easy no bake snacks.
STEP 1: Ingredients
Chunky style peanut butter ( the cheap stuff is just as good if not better)
Graham crackers
Saltines
Melting chocolate
Wax paper or foil
Graham crackers
Saltines
Melting chocolate
Wax paper or foil
STEP 2:
Start by crushing 4 whole squares of graham crackers and about 4-5 saltines
Save a few extra i case you need to add more after the next step
STEP 3: Mix the Ingredients
Star adding a cup of peanut butter to the crumbs . The mix should be firm but not to dry or too wet.
It needs to be able to be firm enough to roll into balls
I start with about a cup and adjust until the mix is just right
STEP 4: Adding the Mix
After you have either rolled your mix into balls or if you want to just drop mix by the tablespoon , put your melting chocolate in the microwave for the recommended time on package. Be sure to check it periodically to make sure it doesn't burn.
As soon as you take out of microwave, star dropping a few balls at a time and gently covering each ball.
Carefully scoop them back out and place on wax paper covered cookie sheet.
Toss them in the fridge for about 20 min. Enjoy!
2 Comments
amberrayh 9 years ago
I've never heard of this recipe before. Sounds delicious!
PaleHorseRider 9 years ago
They're also known as buckeyes...
