Choosing Coffee Beans
Intro: Choosing Coffee Beans
If you are a pedestrian coffee drinker like I am, facing the decision of which beans to buy for home brewing can be daunting. There are too many brands and too many variables to make immediate sense of it all.
So I turned to my friends Joe Speicher & Mark Wickens of Ground to Grounds (www.groundtogrounds.com), a rad online coffee publication, to come and help me get a handle on where to start when choosing the best (for me) coffee beens.
STEP 1: Learn What You Like
There are only two types of commercial coffee beans available, Arabica and Robusta. Arabica is grown in high altitudes and is known for it's smooth, slightly acidic taste. Robusta is grown in lower altitudes and is known for it's stronger, more bitter taste. From what I understand Arabica is considered a higher grade bean, but that again depends on how it is grown and treated on it's journey to the roaster, and doesn't necessarily guarantee a quality product. (As an example, Maxwell House instant coffee is 100% Arabica...) So unless you plan on becoming a connoisseur, I would suggest not worrying about the type of bean, and instead focus on finding a (local & ethical if possible) brand/roaster that looks after that for you and makes a quality bean that meets your caffeine content and taste bud needs.
How to determine what you like:
Taste
If you're like me, you want that first coffee of the day to be consistently delicious. Finding that dream cup will take some trial and error.
Since most coffee drinkers have been to a Starbucks at least once, an easy place to start is for me to ask if you like their house coffees. If the answer is no, then you are most likely going to want to be on the look out for a light colored and dry bean (as pictured on left). This is going to offer you a smoother taste, with different levels of acidity depending on how it was roasted without that classic Starbucks dark, bitter bite. If your answer to my question is yes, then chances are you are going to like a bean that has been roasted longer, which brings more oils to the surface of the bean giving it a dark and shiny appearance (as pictured on right) and a bold, bitter taste. It's worth figuring out that out to start and then you can delve into the subtleties within each of those groups to find 'the one(s)'.
Caffeine Content
Contrary to common sense,dark roasts actually have less caffeine than medium or light roasts - light roasts having the most of all three. Espresso beans tend to be in the medium roast realm, so if you are looking to maximize your caffeine intake that way, go for a medium-light roast. Medium-dark will offer fewer high kicks.
STEP 2: Ground Vs. Whole Bean
If you prefer to buy pre-ground beans, another way to tell the difference between the dark/oily beans and light/dry ones other than color, if they're too close to tell by looking alone, is to test the consistency of the grounds. If when you tip the bag the grounds are sticking together and moving in crumbly clumps, then that's the dark/oily bean (as pictured on left). If when tipped, the grounds all run smoothly downhill as sand would, then that's the light/dry bean (that's them on the right).
Without a doubt the freshest and best tasting coffee is going to come from beans that were ground only moments before being used (for either espresso or drip coffee), so buying whole beans is highly recommended. But whichever choice you make, try and make sure that what you're getting is fresh. Fresh means that it hasn't been on the shelf for more than a week before going home with you. I would recommend asking for the best selling bean to start your taste testing, as that will undoubtably be the most replenished = freshest!
I would like to thank Joe & Mark from Ground to Grounds (www.groundtogrounds.com) once again for giving me the seeds of info I needed to start making better decisions for my morning brew!
Now go forth, explore your local roasters, and find your favorite!
For my Instructable on How to Pack an Espresso Shot, click here!
23 Comments
chandola.neha10 7 years ago
A well explained article on coffee beans. If you are a coffee fan visit www.beansnbrews.in and grab the rich collection of coffee and coffee beans, <a href="http://www.beansnbrews.in/">buy coffee online </a> and enjoy the best flavours.
panakanic 10 years ago
So, where does someone in a very rural area find good beans to roast at home? And how would it be done, in a hot-air corn popper, or other common kitchen hardware? Anyone? I would love to give it a try!
friedcoffee 7 years ago
I would suggest to go with Ethiopian Yirgacheffe and Hawaiian Kona....try these beans as they are considered as the best all over. Here are a few more http://www.friedcoffee.com/which-are-the-best-coffee-beans-to-buy/ . Hope this helps to get the best beans home.
hackney1 10 years ago
One popcorn popper Instructable I found: https://www.instructables.com/id/How-to-Roast-Coff...
I also use sweetmaria's green beens, for several years.
buck_99 10 years ago
Try sweetmarias.com or ccmcoffee.com for green coffee. I used hot air popcorn poppers for about ten years. Need to make some modifications to roast beans, and need to know what you're doing. Plenty of youtube stuff out there to see others work. Using a purpose made GENE roaster past 3 years.
riff raff 10 years ago
I use a hot-air popcorn popper from a thrift store. I get my green beans from
http://www.sweetmarias.com/ (No affiliation...I've just been a customer for the last five or so years.)
Research info at Sweet Maria's, and http://www.coffeegeek.com/guides/popperroasting
Search for first and second crack. Those sounds are how you tell how deep the roast is. Don't go nuts at first, thinking that dark roasts are better. Historically (unless you're talking about espresso) dark roasts are used to cover up the poor taste of inferior beans.
And, as someone has already said, let the beans "de-gas" for 24 hours or so before grinding. Freshly roasted coffee de-gasses carbon dioxide for a while. That's why coffee bags have those one-way valves built into them. Hence, canned coffee is already stale.
BobL69 8 years ago
Thanks for the post. I have never tried any of Starbucks house coffees. I think it would be a good idea to try and few and see if I like the flavor. I really like the light colored and dry bean. I don't know if I would enjoy the taste of bitterness, but I guess I wont know until I give it a try. I also had no idea that a darker bean has less caffeine. That's something I may like about the darker coffee. http://www.majesticstarcasino.com/dining/jackpot-java/
jeanniel1 8 years ago
Good general explanation for coffee! Thanks!
maji101 9 years ago
Coffee beans differ depending on where they're grown. Which coffee bean is the right one for you? Here's what you should look for http://coffeelounge.net/coffee-beans/
david.leclear 9 years ago
Another good article for choosing your beans is found here: http://www.backtothebean.com/the-bean-blogger/2015/1/19/making-the-best-cup-of-coffee-at-home-choosing-the-bean
rnorton2 10 years ago
Thank You, I've learned something new today. so i guess my next step is finding the right balance of caffeine and smoothness. taste test, YUM!
jeepneyko 10 years ago
you forgot the first phase in choosing the right beans... 1) avoid damaged/ broken beans 2) get rid of beans with ''borer'' holes.
There's an Italian coffee brand that has computerized mechanism that chooses the right (almost perfect) beans as they pass through the conveyor. And there's another one coffee company here in the Philippines that uses the same technique but manually.
tclark449 10 years ago
Very informative instructable, thank you. Also learned quite a bit from commenters. Never gave a thought to roasting my own beans...something to consider, though!
randytsuch 10 years ago
Good coffee will have a roasted on date, and not an expiration date. Coffee is stale a few weeks after it is roasted, and is also stale a few hours after it is ground. So for really good coffee you need a burr grinder and coffee that you know when it was roasted. I roast my own, I give it a couple of days to rest after roasting.
gsaxon 10 years ago
OhWheelie 10 years ago
I'll 3rd what BARKing says. I've been home roasting for ten years. Until you've tried fresh roasted (I prefer to let it offgas for 12-24 hours before brewing) you have no idea what coffee should taste like. Stale coffee has no resemblance.
bob3030 10 years ago
snosheu 10 years ago
