Introduction: Christmas Shadowbox - Decor Item
Hello everyone!
In this Instructable I will show you how you can make this beautiful Christmas shadowbox! It's a beautiful gift for a friend who loves Christmas, or for yourself!
If you like this instructable and the video, don't forget to subscribe to my YouTube Channel. Thank you!
Here is a quick link to subscribe: https://goo.gl/3qZJWR
Tools I used:
- Jointer/planer
- Tablesaw
- Sander
Materials I used:
- Wood glue
- Clamps
- Craft paper
- Utility knife
Step 1: The Paperwork
Picture 1: Make a border of 10mm around 4 craft papers (thick paper). On the first paper you need to draw two trees, (left and right) they are easy to do free handed.
Picture 2: On the second paper you need to draw 2 more trees, beside the ones on the first paper. You can check by laying them on top of each other.
Picture 3: Cut out the trees with your utility knife.
Picture 4-7: Here you can see what it looks like when you're done. For the reindeer and the christmas tree you can search on google for some easy silhouettes.
Step 2: Assembling the Inner Box.
Picture 1: To glue up the shadow box you need wooden spacers. These need to be as long as your paper is, I'm using the standard A4 format. So I used 2x 190mm long sticks and 2x 277mm long sticks. All the spacers need to be 8mm wide x 10mm thick.
Picture 2: Use a little bit of wood glue to glue the spacers in between the different layers of paper.
Picture 3: At the back I'm glueing a white craft paper with some holes in it to let the light through.
Step 3: The Wooden Box - the Woodworking Part
Picture 1:
My dimension of my wooden planks:
2 x 8mm thick, 6,6cm wide and 21cm long
2 x 8mm thick, 6,6cm wide and 31.7cm long
Cut a groove for your plywood panel of 4mm thick. You can do this with a tablesaw or a router.
Picture 2: For one of the short pieces cut all the way through, so you can access the inside of the box by sliding away the plywood backer board.
Picture 3: Plywood backer board: 21,7cm wide, 30,7cm long.
Step 4: Assembly Time!
Picture 1: Now it's time to glue the inner box to the outside box.
Picture 2: Because I didn't used miter cuts, I'm making a miter border to go on the front of the shadow box. the dimensions of the slats: 22mm wide, 8mm thick. This way the paper border is also nicely covered.
Picture 3: Round over the edge of all the slats on the routertable and glue them on the box.
Picture 4: Make a little knob/handle for the plywood back.
Picture 5: Put some LED-lamps at the back. As you can see, I'm just using some ugly painterstape :).
Picture 6: Slide the plywood in place, and you're ready to shine with your shadowbox!
If you liked this instructable and the video, don't forget to give me a vote in the "Holiday decor speed challenge" contest.
Thank you!
Happy Holidays!
