Christmas and More Lights
2,510
29
Introduction: Christmas and More Lights
About: I like to create new things! I'm very interested in IOT and just Internet Stuff. I am not responsible for any injury or deaths caused by my projects.
Using Arduino,LED's, and Paper we can make easy and cool Christmas lights that can take the shape of anything. This project is simple and will only take you about 2 hours. If you like this project please vote for me in the contests this project is entered in. Without further talk lets start.
Step 1: Make the LED Strip
I'm using neopixels available here.
(make the strip to a size that fits your needs)
Solder your 5v pins to the 5v pins then your Din to your Dout pins and finally your GND pins to your GND pins.
Connect it to your arduino via pin ~3 (unplug the arduino when connecting it)
Step 2: Code the Arduino
Download and Install the neopixel library
use the "strandtest.ino" to test your strip
Step 3: Make Your Frame
I made two 6_1/2" x 6_1/2" cardboard squares then four 1" x 6_1/2" pieces for the sides.
Tape everything together and tape aluminum foil to the bottom.
Step 4: Make the Screen
cut out your shape, glue it to an white piece of paper, then glue any internals.
Step 5: Finishing
Tape everything together, put the lights inside, and connect the arduino.
Step 6: Admire
Thanks for reading! I hope you enjoyed this project and make it yourself. If you liked it please vote for me!
Make It Glow! Contest
Homemade Gifts Contest 2015
Tech Contest
Tech Contest
Be the First to Share
    • The 1000th Contest
      The 1000th Contest
    • Battery Powered Contest
    • Hand Tools Only Challenge
    2 Discussions
    jeanniel1
    jeanniel1
    4 years ago
    What a great simple idea for lighting - can be used for anything - lamps, decorating effects, night lights! Thanks for putting this together!
    Funguypro
    Funguypro
    Reply 4 years ago
    no problem thanks for reading
