Introduction: Christmas Ornament Cookies
These Christmas ornament cookies are unique and make a great gift!
Step 1: Supplies:
Sugar cookie dough- home-made (No Fail Sugar Cookie recipe below) or store-bought mix
White fondant
Fondant and gumpaste star tool
Fondat and gumpaste ball tool
Rolling pin
Cake sparkles and/or edible glitter
Edible glaze spray
Edible markers
Edible pearl dust- various colors (I used red, bronze, silver, white) but there are several colors available
Paint brushes (for food)
Tweezers- only used for food
Small cup (for water)
Water
Paper towel
Parchment paper
Brush for dusting on pearl dust (I use a new blush brush)
Small round cookie cutter -optional
Christmas ornament cookie cutter (or make your own https://www.instructables.com/id/Quick-And-Simple-FlowerClover-Cookie-Cutter-From-/)
Gift box
White tissue paper
Black food coloring
Shortening
Cutting board/working surface for fondant
I love this recipe because the dough holds its shape and won't spread during baking.
No Fail Sugar Cookies
Ingredients
- 3 cups flour
- 1 ½ tsp. baking powder
- 1 cups unsalted butter
- 1 cup sugar (white granulated)
- 1 egg
- 1 tsp. vanilla extract or desired flavoring
- ¼ tsp. salt
Instructions
- Cream butter and sugar until light and fluffy. Add egg and vanilla. Mix well. Mix dry ingredients and add a little at a time to butter mixture. Mix until flour is completely incorporated and the dough comes together.
- Chill for 1 to 2 hours
- Roll to desired thickness and cut into desired shapes. Bake on ungreased baking sheet at 350 degrees F (176 C) for 8 to 10 minutes or until just beginning to turn brown around the edges.
Yield: about 2 dozen
Step 2: Make the Cookie
Roll out your dough a little thicker than a regular cookie (about 3/8 of an inch) You want to ensure it's thick enough to indent in the centre. Use your ornament cookie cutter to cut out your cookies.
As you can see, I made a cookie cutter to save money based on this awesome instructable: .https://www.instructables.com/id/Quick-And-Simple-FlowerClover-Cookie-Cutter-From-/
It was easy - only need a can and a pair of pliers!
Cut out as many as you need (I made 6 for this particular gift box)
Step 3:
Make a little circular mark in the centre of the the cookie. You can use a cookie cutter or something that size (like the top of a spice bottle)or just wing it.
Indent the cookie with the star tool (as shown). Don't worry if it's not perfect, you will be covering it with fondant and repeating it - this is just so there is some ident in the cookie itself.
Step 4: Bake the Cookies
Bake the cookie at 350 degrees for 10-12 minutes
While the cookies are baking, roll out your fondant to desired thickness (1/8 of an inch is average)
Step 5: Put the Fondant on the Cookie
Cut out the fondant ornament shapes with your ornament cookie cutter.
* The cookie will expand a little while baking, so you may need to go over the cut out with a rolling pin to widen it a bit. Go over once both ways (across and top to bottom)
When the cookies are cool, rub a little water on the back of the fondant (to make it stick to the cookie and place it on top of the cookie.)
Indent the cookies with the ball tool or your thumb. Use the same process (the circle as the guide) and indent the fondant with the star tool.
Step 6: Decorate the Cookie
Put a little circle in the middle of the cookie, then color outward and in the creases with an edible marker
Dust with pearl dust
Step 7: Make the Hanger/hook
Color a little white fondant with a touch of black food coloring to make grey
Then use your cookie cutter to cut out the hanger, as shown.
Cut and shape and decorate the hanger (by using a fondant tool or knife, as shown) and put a little water on it to paste to the cookie
Take some of the same fondant and roll out into a skinny snake, bend it into a 1/2 circle and let it dry. When it is dry (at least 15 minutes), attach to the cookie with some water
Brush the hanger/hook with silver pearl dust
Step 8: Finishing Touches
Dip the paint brush in a little water, then go over the area colored with marker. Sprinkle on some cake sparkles
Put the hanger and hook on with a little water for glue (may have to hold the hook in place for 10 seconds or so to ensure it stays) Then keep it leaning on something the same height, as it dries (as shown).
If you wish, paint a little water around the edge of the cirlce and shake on the edible glitter (OR use tweezers - I find I have more control this way)
Spray the whole thing with edible glaze.You may have to spray it twice to get a good shine.
Step 9:
Put some tissue paper in any kind of gift box (an ornament box is best, if you can find one) and place cookies inside.
Holiday Gifts Contest
Cookie Contest
7 Comments
7 years ago
These are cute! You could skip the glaze altogether and use a steamer if you have one. It'll make the fondant sweat a bit and the result is a shine. That way you will never miss a spot :)
10 years ago on Step 9
These cookies are so pretty and artistic! I've never heard of spray glaze before. It really added a beautiful shine!
Thank you! You can get this edible glaze at cake decorating/hobby stores. Or you can order it online from several sources (global sugar art is one). Confectioners glaze can also be painted on for a clear, shiny finish, but it's more of a pain to work with because you have to buy the remover as well and clean your tools after.
I could only find the spray in the UK, so thanks for the info.
The Confectioners glaze doesn't even sound edible, but I see (after googling) that it is! And they make a "thinner" for it, too? How funny is that?!?
Sugar Art totally fascinates me!!!
The thinner/remover is essential or it won't come off your utensils! The downside is having to 'paint' it on. So, if you have anything that smudges/smears, then you are better off with the glaze spray. I have also used "Pam" (or any non-stick vegetable spray) to shine up my cakes. And I have also sucessfully rubbed vegetable shortening on my cakes to give it a 'plastic' look. The possibilities are endless!
I know - sugar art is amazing....I think I'll do some instructables on poured and spun sugar in the future - they are really cool!
Love the way you made the ornament cookie cutter - very smart! They look great :D
Thanks!
