Cigar Tube Humidifier
Intro: Cigar Tube Humidifier
This compact humidifying element will occupy minimal space in your humidor, allowing you to fill your humidor with more important stuff.
** FINAL STEP UPDATED **
STEP 1: Gather Materials
To make your own compact humidifying element, you will need the following:
-- propylene glycol crystals
(I get mine from Cigars International, but other online cigar stores stock them)
-- an empty aluminum cigar tube
-- sandpaper
-- 1/8 " drill bit and drill
-- center punch
-- sandpaper
-- center punch
STEP 2: Strip the Tube
I sanded all of the paint off of the cigar tube for aesthetic purposes, but this step is optional.
STEP 3: Prep and Drill
Mark the tube with the punch in 1/4" intervals along a straight line, then drill.
STEP 4: Finish and Fill
I squished the rather malleable tube in a couple places while I was handling it, so I used a smaller cigar tube to pop out the dents. After you are satisfied with the tube's condition, fill it with propylene glycol gel.
STEP 5: Put It to Use
Cap the tube and set it in your humidor. Admire the vast new space made available to you for cigar storage.
** UPDATE **
After a little more than a month of use, I determined that my humidifier was registering consistently low hygrometer readings, despite rehydrating the gel a few times.
To solve this, I drilled a large number of additional holes (on all sides) to allow for better air circulation and evaporation. It works -- keeps my humidor interior within the requisite 66 - 79% humidity zone.
Below is the finished product.
** UPDATE **
24 Comments
HTWTUSA 11 years ago
I'll be making this for my travel box this weekend...I'm tired of buying humo-packs to keep my CAOs nice and young...xD
Thanks.
One note: If your cigars come in a plastic sleeve, you don't have to remove them to humidify them...just open the end, or cut it flush with the stick to allow a little of the moisture to hit the end. If the end stays moist, the rest of the stogie will, too.
Cheers!
moGuyver 11 years ago
uberchoob 15 years ago
moGuyver 15 years ago
shaitand 12 years ago
projectbronco 12 years ago
Water alone can result in humidity up to 95%. Propylene glycol crystals will absorb excess humidity over 70% resulting in 2 way humidification.
I appreciate the DIY spirit of the instructable but a DryMistat is essentially the same thing with a breathable plastic membrane that allows it come in contact with the cigars without over humidifying the near ones and they only cost about $8 so there is little if any economic or practical benefit to this.
cbossio 12 years ago
moGuyver 12 years ago
Kalyfrans 15 years ago
moGuyver 14 years ago
Clodester 15 years ago
CrustyCrayon 15 years ago
arhodes18 15 years ago
wasserman08 16 years ago
geterkikzkid 15 years ago
R4Man18 16 years ago
mitchellator 15 years ago
moGuyver 16 years ago
In answer to your second question, yes aluminum does oxidize, but not in the same way that iron does -- aluminum oxide is almost unnoticeable and won't compromise the integrity of the tube.
