Cinder Block (CMU) Offset Smoker
Intro: Cinder Block (CMU) Offset Smoker
For a small fraction the price of a heavy steel smoker, you can setup a large capacity cinder block version. Not only will it be cheaper it will be better insulated. Follow the instructions attached for a very effective, efficient and not bad looking unit.
STEP 1: Design & Dimension
Review design dimensions.
STEP 2: Clear Area
- Clear appropriate sized area with offsets as needed.
- Soften and level dirt or ad layer of sand.
STEP 3: Procure Cinder Blocks & Bricks
- Cinder Block: 8x8x16 (Qty. 60)
- Cinder Block (1/2): 8x8x8 (Qty. 15)
- Cinder Block (Caps): 8x2x16 (Qty. 16)
- Clay Brick: 4.5x9x1.75 (Qty. 24)
STEP 4: Base Layers
- Place base layer of cinder blocks and use level to confirm flatness.
- Alternate seem on each level.
- Eliminate all air gaps.
STEP 5: Complete Firebox
- Build firebox with rotated CMU bricks for air inlet and outlet as shown.
STEP 6: Complete Chimney Structure
- With a chisel, break a 1/2 brick into half again so that the chimney has an opening as shown in picture.
- Stack chimney to 3 blocks high for appropriate air draw.
STEP 7: Add Top Caps
- Place top caps on alternating seems from cinder blocks underneath. (Top caps will ad a flat surface for lids to seal better)
STEP 8: Lid Construction
Lid Dimensions: 30.5" x 38" (Qty. 2)
- Cut plywood to dimensions.
- Procure Heat Shield Insulation (4 ft x 6 ft) and cut to same dimension as plywood.
- Using a staple gun, apply insulation to bottom side of wood.
- Fasten two lid pieces with hinges in middle and and handles.
STEP 9: Add Clay Bricks
- Line the inner firebox with clay bricks for extra heat protection for the concrete blocks.
STEP 10: Rebar Grate Support
- Measure off alignment for rebar supports. (3 places)
- Using a 1/2 inch concrete drill bit, drill holes through only one side of blocks.
- Insert 25" long, 3/8" rebar.
- Procure or cut, 3/4" X 13 ga. flattened expanded metal sheet to 22" x 53"
- Place expanded metal on top of rebar for a cook grate.
STEP 11: Fire Box Lid
- Procure 29" x 31", 3/16" thick carbon steel plate.
- Drill and bolt in handles for easier removal (not shown)
3/16 steel plate is necessary for firebox as temperature here will be too extreme for thinner materials
STEP 12: How to Use
Now you're ready to test it out!
- Use a left over block as a damper for your incoming fire vent. Slide back and forth to adjust heat.
- Leave stack vent open at all times.
- Add another expanded metal grate over the fire-pit if you would like the option to grill over the fire. (Good for tri-tip and chicken)
(This specific pit has about a 20 degree difference from one side to the other....which is actually very impressive.)
47 Comments
johneriv70 3 months ago
shsdawgs 9 months ago
1) Make sure the first layer of block is level and square.
2) If possible, have the metal shop weld on a couple of handles. It’s worth the extra couple of $$.
3) Invest in a good pair of welders gloves.
4) I found it was easier to get up to temp and control the temp by removing the top course of large blocks from the fire pit. This allows the heat to vent more efficiently into the cooking chamber and you will need a smaller fire.
5) For the cook box, get a couple of cheap oven thermometers (less than $5 each) and place them right on the grill. Much more accurate temp.
joed33 1 year ago
bradbraden4 1 year ago
chrisprras 2 years ago
scottcofield 2 years ago
jason_5hundy 2 years ago
bryangoodell 3 years ago
jason_5hundy 3 years ago
Peterjohndendulk 3 years ago
mikelandrum 3 years ago
natecrooks20 3 years ago
Haus2005 3 years ago
This is fantastic though!! Great work!!
stephen.dobek 3 years ago
rathomas80 3 years ago
Rhk0862 4 years ago
Rick
amkucera 4 years ago
jason_5hundy 4 years ago
