Class Computer Build
Intro: Class Computer Build
First things first, gather your materials and prepare your work station.
STEP 1:
Once you have your motherboard out, insert the CPU and RAM very carefully so as not to damage the CPU pins.
STEP 2:
When preparing to screw in the motherboard you will need to first find where the screw will go in the case.
STEP 3:
After carefully inserting the RAM and CPU, attach the fan on top of the CPU, and insert the IOS shield after screwing in the motherboard inside the case
STEP 4:
Once the motherboard and the fan are installed all that is left is to install the driver which is shown in the right of this picture.
STEP 5:
Make sure that the driver that you are using is compatible with the case and will fit and not be loose or too tight.
STEP 6:
Then all you do is seal up the case and you're done.
8 Comments
connie46 8 years ago
pourquoib 8 years ago
graefawks 8 years ago
Wolfbane221 8 years ago
I could have mentioned the thermal paste, but I had made my point that the information isn't really there and an example of this - IE the strap. If I had compiled a list of everything that was wrong I could have just made my own - and my intention was for the OP to bulk it up a bit since he clearly has the knowledge and expertise.
At no point had I mocked the original poster or made out they were stupid and rather was just giving my advice - IE not enough information for this to be a how to. The site is called Instructables, and if I was reading this as someone who wasn't too clued up on computers, I would still be none the wiser. If you took that to be rude then that's hardly any fault of mine when I made clear in both posts that I was saying it with sincerity. I didn't realise he was in middle school but I don't see how this is relevant.
If you found it informative and it taught you how to build a PC from scratch then that's great. To the OP, as implied in my other posts, I did not mean to cause any offence and was only offering my advice that there was not enough information.
mretuck 8 years ago
I agree. There are not enough details to be a useful instructable. Furthermore, learning to receive constructive criticism is a life skill the teacher likely had in mind when/if creating the assignment, and that is exactly what was given.
The OP should edit and finish the assignment. Details like grounding, thermal paste, and perhaps installing the OS are important steps.
tovapearl 8 years ago
Wow! I dont think i could make this but it looks great!
