Clean Your House Gutters by Yourself
Intro: Clean Your House Gutters by Yourself
To keep your gutters in tip top condition you ideally need to clean and clear them at least twice a year. This’ll help to prevent water damage to your walls, frames and foundations. Use the following easy guide on gutter DIY to safely tackle any blockages:
STEP 1: Ladders
You’ll need to select the most suitable ladder for the job, depending on the height you need to reach. Step ladders can be used for single storeys and extension ladders for 2 storey buildings. Combination ladders are versatile and can operate as a step ladder and extension ladder. A ladder stay or stand-off will make your ladder more stable by keeping it away from the wall giving you space to access the gutter. Always stand the ladders on flat, firm ground.
STEP 2: Scaffold Towers
If you think you’d be more secure working from a scaffold tower there are many different types to choose from. They have large work platforms which can fit you in comfortably along with your tools. They’re rigid and stable and provide a much safer working environment for you. They’re also self-supporting so you don’t need to lean them against the wall. Materials are generally aluminium or steel which eliminates the risk of slipping.
STEP 3: Protective Gear
To prevent any injury to your hands you should invest in someindustrial gloves. Single palm gloves are designed to maximise comfort for light duty outdoor jobs. They’re 100% cotton with wrist options and available in many sizes. Palm dip gloves offer abrasion and puncture resistance too. Wear protective goggles to avoid any eye injuries. These are available in a variety of options including vented and breathable foam. Remember to wear shoes or boots with non-slip soles.
STEP 4: Tools
If scooping out the debris with your gloved hands isn’t enough you may need to use a gutter scoop. These come in a range of sizes and are thin enough to fit into the gutter system. Long handled gutter tools make the job even easier. Take a bucket with you to collect all the waste. A brush will be needed to scrape away any residue as this will smell if left. Gutter cleaning brushes specifically designed with round heads and long handles will let you reach as far as possible without having to keep moving position.
STEP 5: Other Equipment
You may want to avoid the scooping and scrubbing processes by using a pressure washer. When you turn it on the high power spray will effectively remove any small blockages. Clogs and debris will be carried over the sides of the gutter and the downspouts. You need to remember that this can cause a great deal of mess! You would need the security of a scaffold tower to operate this method safely as the pressure washer needs to be on a level with your gutters.
STEP 6: Consider Getting Professional Help
After reading this article you may be wondering if hiring expert gutter cleaners may be the simplest way to get the job done! Professional technicians will use hi-tech equipment to complete the clean safely and quickly. You’ll also benefit from their maintenance help and advice alongside gutter repair and replacement if you need them.
