Clean a Wacom Intuos Mouse
Intro: Clean a Wacom Intuos Mouse
The problems: your hand is an oily filth-generator and the bottom of an Intuos mouse is a black hole for dust and gunk. After a while, build-up on the bottom makes the mouse harder to maneuver.
The solution: an old shaving razor and some rubbing alcohol.
Read on for more hand-holding.
STEP 1: Marvel at How Dirty Your Mouse Is and Gather Some Sharps
Locate the bottom of your mouse and be amazed at all the dust it has somehow found.
Then check your inventory of sharp objects: an old multi-blade disposable razor is perfect for the job, but any relatively sharp knife works too (e.g. X-acto knife, Swiss army blade).
And just in case you were wondering, the mouse works through electromagnetic induction.
STEP 2: A Shave...
Using a disposable razor:
Preferably one with more than one blade (this leaves a nice, clean surface on the felt). Shave the bottom like you would normally shave, well, yourself. Don't push down hard and don't angle the razor too low or it will take off chunks of the felt and cut into the plastic along the edges of the mouse. Go slower along the edges to avoid nicking the plastic. Also go a little slower over the sticker in the center to avoid cutting the edges of the felt.
Any other type of blade:
Hold it perpendicular to the surface of the felt and scrape LIGHTLY. If the blunt side of the blade is about the same thickness as the cutting edge and you can use that to scrape without cutting yourself, do so (the non-cutting edge of an X-acto knife works very well). You don't want to scrape too hard or at an angle because it'll take off bits of the felt.
STEP 3: ...and a Haircut.
Now the mouse should be a LOT more sightly. You can use an X-acto knife or something pointy and sharp to carefully clean out the junk along the edges of the felt. Once again, don't push down too hard or you'll cut the plastic.
Then, depending on how obsessive-compulsive you are, you should be done with the bottom of your mouse.
STEP 4: Finally: Clean Off Your Hand-filth.
Now grab some sort of cleaning solution and some sort of cleaning material and wipe genlty. I had some isopropyl alcohol (generally recommended over ethyl alcohol for electronics) and Q-tips.
Your mouse might not look that dirty, but trust me, it is (see picture). Another way to disgust yourself is to try this with your game controllers.
Well, this is as clean as I care to get my mouse... if you're extraordinarily obsessive, you can clean the cracks with a toothbrush or something.
Have fun re-dirtying your now-clean mouse!
20 Comments
noparallel 11 years ago
L-A 8 years ago
I don't know how you know this, but it worked on my Intuos 4 mouse.
dtearth 9 years ago
You're a lifesaver, thanks!! Worked for my intuos4 mouse.
Dr.Hax 14 years ago
i like the teflon idea, but no place around here sells rigid teflon sheets or sticky teflon tape, and the adhesive on the removable screen protectors doesn't seem to damage the felt. the screen on a blackberry touch is very close to the size of the felt pad btw, with just a tiny bit of overlap to trim.
Dr.Hax 14 years ago
mrlunna13 13 years ago
Jesse
brokenlead 15 years ago
nerfer192 16 years ago
Whacko 16 years ago
Whacko 16 years ago
retroleum 16 years ago
Whacko 16 years ago
KelliShaver 16 years ago
LinuxH4x0r 16 years ago
theRIAA 16 years ago
ac1D 16 years ago
GorillazMiko 16 years ago
