Cleaning Vinyl Records
1,182,451
239
134
Introduction: Cleaning Vinyl Records
To ensure the best sound and least amount of wear on your records, it is essential that they are kept clean. My rule of thumb is to never play an album until it has been sufficiently cleaned.
Here is my tried and true method for liberating a record from all the dirt, dust, mold and fingerprints it may have acquired over the years - all without special fluid. I’ll show you my method that utilizes soap, water and a record brush.
I’ve tried a few different methods over the years, including the traditional fluid and bush method and vacuuming the surface (with a gentle brush), but that would still leave dirt behind.
Then I tried the soap and water method. I finally got ALL the dirt and grime of every record I tried, on the first cleaning too. One record was completely which with mold/mildew. After cleaning, the record is visually perfect and plays well with barely any pops/clicks!
For records with only light amounts of dust, I would recommend just brushing them off with a carbon fiber brush before playback. As any record collector knows, only about 10% of used records actually come in that condition. For the other 90%, wash them off.
Remember, the best cleaning in the world just removes all the dust and dirt. Some records will have scratches and groove wear. No amount of cleaning will fix this. So after cleaning, some record may sound “perfect” and others maybe not so much.
Step 1: Gather the Items
You'll need the following:
-A Basin of some kind
-Dish soap (any kind will work)
-A record cleaning brush/pad (Discwasher style)
-A few washcloths
-A source of warm water
-A sink with faucet
-Records to wash
-A clean surface to put the records on (their cardboard sleeves)
-Two hands
-Rubber gloves (if your going to be doing a number of records at a time)
-Towels to dry off the records
Step 2: Prepare the Water
Put an extremely small about of soap in the basin, and then fill it with about 3-4" of warm water. To active the soap, stir it around with your hand while filling up the basin. Now place the basin on a counter top or other comfortable surface where cleaning your records.
Step 3: Washing the Records
Put a record in the basin, and turn it around by moving the edge with the palms of your hands (as to not touch the grooves).
Once the whole surface of the record is wet, grab the record brush and get it wet. With one hand, hold the record (with your palm) and with the other, move the brush in a circular motion about 10 times. I like to do 5 counter-clockwise and 5 clockwise. If you've got heavy grime, you might want to do more. just make sure not to touch the label. After one side is clean, flip it over and repeat.
Step 4: Rinsing
After you've gotten the record clean, put it in a sink and run some cold water over it, and turn the record with the palms of your hand. After one side is clean, flip it over and do the other.
After it's clean, turn off the tap and let the water run off.
Step 5: Drying
Now that most of the water has run off, put a wash cloth in your hand, and grab the record with it. Now put another washcloth in the other hand, and grab the record.
With one had, hold the record, and with the other, dry it off. Once it's dry, flip it over and do the other side (which should be most dry by now).
Once the record surface is dry, put the washcloths on the labels and press against them with your hand. This should get the labels dry.
After the record is mostly dry, set it on top of it's cardboard sleeve, then place it somewhere and let it dry for several hours.
Step 6: Storage and Playback
I'd recommend that the record is stored in a sleeve (the paper jacket inside the cover). Paper is fine, but does shed over time, so your records might have a little bit of stuff on the surface. Later records (late 70s and 80s) have glossy paper and even plastic sleeves to prevent this.
Either make sleeves out of wax paper (this will be a future Instructible) or buy some paper or plastic ones (they can be found online).
When handling records, make sure to only touch the label and edge, because finger oil acts like glue and dirt will stick to it (I've seen many a used record with blotches of dirt in the shape of finger prints).
Unless you seriously mistreat them, you'll probably never have to wash your records again or even use cleaning fluid. Just get the stray dust off with a carbon fiber brush before playback, clean the stylus (with a stylus cleaning brush or a lint free cloth and a drop of alcohol), keep the turntable clean and close the dust cover during playback.
Additionally: You may encounter a record with a sticky substance or something which doesn't come off via soap and warm water. In this case, I would try a cloth and Goo Gone and/or rubbing alcohol.When you are done, rise that area off with water to remove the chemicals.
Be the First to Share
    • Envision the Future of the Lift Truck Student Design Contest
    • Make It Modular: Student Design Challenge
    • Wearables Challenge
      Wearables Challenge
    134 Comments
    HorridMonster
    HorridMonster
    1 year ago
    I had all of my records in storage then the place flooded. Now I have around 200 albums that have mouldy covers. I haven’t looked at the record’s. I’m going to have a to spend a lot of time cleaning then. So this is very helpful. I doubt they will ever be perfect again but just having a clean collection will be nice. Thanks fir the advice. If anyone has a better way to rescue my collection please advise me. Best.
    tdrapp56
    tdrapp56
    5 years ago
    Thank you for all the very useful information. I just bought a new turntable after about 20 years of not having one. I have records I collected as a teenager in the 70s as well as those my parents had from the early 50s and are older than I am (60). I have tried through the years to at least make sure that they didn't warp. I've played some of them and it was so nice to hear some of the stuff that is not available on CD or in the cyber world. My project for the next few weeks will be cleaning them all and then enjoying all that wonderful music.
    maddlynne
    maddlynne
    Reply 1 year ago
    Amen to that
    Captain Starlite
    Captain Starlite
    5 years ago
    LESS NOISE!
    Make your records as quiet as CD's. Well not quite but better than you would expect. I have been playing records for 60 years and like you I have suffered the usual background surface noise on vinyl records. I have found a WD40 product to clean my records and reduce static and noise. It's WD 40 specialist anti friction Dry PTFE Lubricant. Squirt four small amounts equally spaced on the on the center of the tracks and clean in a circular motion with a soft tissue.You will notice the tissue will collect dirt change to a new tissue. Keep polishing until all trace of liquid has disappeared and the record is shiny black. Now the record will feel very slippery. If the record is in reasonable condition background noises will be reduced. On the first play more dirt will pop out of the grooves after which it will stay clean for while with less static.This may even reduce record wear.
    maddlynne
    maddlynne
    Reply 1 year ago
    Thank you for that information!!
    mcmullen.wilbur
    mcmullen.wilbur
    4 years ago
    Very well explained the process to clean the vinyl records with few simple steps. Can you also give some tips how to avoid records from getting warp.
    maddlynne
    maddlynne
    Reply 1 year ago
    There not warpt but they had gotten wet,and the cover is stuck too my albums
    EricJ7
    EricJ7
    Tip 2 years ago on Introduction
    My advice buy the album never open it and listen to that album on your MP3 player. Hey I'm here to help. :-)
    I would NEVER do this.
    I have a collection of 5,800 LPs. I have a machine that by VPI that cost me $400 that does this job without the mess and the risk involved in the manner suggested here.
    marcus_aurilius
    marcus_aurilius
    Tip 3 years ago on Step 5
    NOW you dry with a micro cloth AND AND AND spray them with destilled water!!! step 5
    marcus_aurilius
    marcus_aurilius
    Tip 3 years ago on Step 3
    Bad idea to dunk them in water! USE a sponge! STEP 3, its a no no
    You can buy 2 plungers from hardware shop and remove the handles... then simaltainiously apply them over the labels... should give you a water tight covering to protect the labels...
    TomG201
    TomG201
    Reply 3 years ago
    good tip
    TomG201
    TomG201
    3 years ago on Step 6
    Thanks for making it so simple, I've seen so many complicated methods, including the" Glue method", this way just makes good sense.
    MarioN61
    MarioN61
    Tip 3 years ago
    1Se debe lavar con jabòn liquido y utilizar un cepillo de microfibra, haciendo giros y despuès enjuagar con agua limpia. Otra sugerencia es utilizar agua sobre el disco mientras se està escuchando, esto minimiza la fricciòn y reduce de un modo importante el ruido de fondo.
    Any tips to getting sellotape off vinyl, my husband had a record that was framed, has take it out, but it was secured by double sided tape, any good advice???
    LaserDave
    LaserDave
    One of the most overlooked items that every household has, is PERFECT for removing sticky adhesives from tape, labels, dirt from dust, fingerprints, drink spills etc. It is a cleaner for nearly anything you want removed, it is made from fish oils and is really inexpensive. What is it you might ask? WD-40.
    I have cleaned many, many, many records with WD-40 (I have thousands), I've removed the little sticky "dots" that some DJ's use on the vinyl prior to my getting them, it works like a charm.
    To remove most kinds of dirt from a non-porous surface, simply spray enough WD-40 onto the offending matter to saturate it, then let it soak for 10 minutes or more. Wipe it off and the gunk will come with it. For stubborn material like double-sided (foam) tape, several applications will be needed to get it all off. Don't forget, it will work best if you remove as much of the material you can before you soak it. Labels that have a shiny surface are tough, you need to peel off as much of the label as you can, otherwise the WD will not penetrate into the sticky part.
    If you are worried about the oily residue left behind, you can clean this with Windex or rubbing alcohol, otherwise it will tend to evaporate by itself. I have found that simply wiping the vinyl record with a soft dry cloth will remove most of the WD-40, but I've never had any problems by leaving it dry by itself.
    WD-40 is my first choice for cleaning almost anything. Hope this helps!
    cgimeno
    cgimeno
    Reply 5 years ago
    Ok I have to say, this WORKED. I found a bonus album inside a Herb Alpert Case which turned out to be 12" Cameo Word up Extended version. Well Im an 80s child so I was stoked. But the record was bad with clumps of dirt. I tried alcohol at first but then i tried the wd 40. I sprayed some on a microfiber cloth and wiped gently in one motion around the record. Then I used a damp dishsoap microfiber cloth to clean the wd40 off. then dried with a soft tshirt. I think it still has some wd 40 residue (certainly smells like it) but it plays so smooth now!. And it isnt ruined. :)
