Cleaning a Car Battery Pole.
2,673
10
Introduction: Cleaning a Car Battery Pole.
The negative of my wife's car battery pole is slack to touch. This is not good! It is so slack I can remove it by using 2 fingers.
Step 1: Corrosion.
As you can see the pole has significant corrosion. This needs to be removed.
Step 2: The Tool.
This brass brush is perfect for cleaning lead poles.
Step 3: Cleaning!
Carefully brushing the pole and the clamp, I made sure all surfaces were clean.
Step 4: Completion!
Using a 10mm Spanner I tightened till snug. Now the clamp is secure on the pole and the vehicle ready for the road!
Be the First to Share
    • First Time Author Contest
    • Build a Tool Contest
    • Backyard Contest
      Backyard Contest
    4 Comments
    MarioL111
    MarioL111
    4 years ago
    Contact paste will only protect the connection, not the rest of the metal. Galvanic corrosion is stll an issue. Using cables with a lead clamp for the lead battery post instead of cheaper steel clamps makes a huge difference. Permatex 22058 Dielectric Tune-Up Grease is recommended by the manufacturer for your car battery terminals. I've used it on several vehicles and other equipment with 12 Volt lead-acid batteries. Zero problems with any type of corrosion or connections. Dielectric DOES NOT mean non-conductive per se, but rather polarizable. The full explanation of why it works is lenghty and technical. Always read the manufacturer's instructions!
    davidoxigen
    davidoxigen
    5 years ago
    I can edit my posts later, i hope
    maniacse
    maniacse
    5 years ago
    It is good to use battery contact paste to seal it. Once you have those crystals there, those will be back in no time.
    beaver79
    beaver79
    5 years ago
    It is even no basic. Please...
