Clicking Solder Dispenser Pen
Intro: Clicking Solder Dispenser Pen
Turn an ordinary clicking pen into a solder dispenser, a bit of solder comes out with every click. This takes advantage of the pen's mechanism which actually spins. You can still use the pen as a pen.
Inspired by the simpler (and in a way, better) pen dispenser in the Guide to Field Soldering instructable.
STEP 1: Parts and Tools
-a clicking pen
-a tooth pick
-small length of wood, 4mm x 4mm x 1" long is sufficient
-hot glue gun
-drill with a 3/8" bit
-a tooth pick
-hot glue gun
STEP 2: Preparing the Mechanism
Take the pen apart, place as much of the tooth pick into the ink cartridge, and the other end into the plastic piece that is supposed to be pushing against the ink cartridge. Hot glue the ink cartridge to the plastic piece with the tooth pick helping you make a straight joint.
STEP 3: Drill Hole in Pen Tube
Using a drill and a 3/8" bit, drill a hole 1/2" to 1" away from the end (the end that is the tip of the pen, minus the metal cone). This will let the solder through.
STEP 4: Load Solder
Tape the end of the solder close to the end of the ink cartridge, just below the plastic piece you glued the cartridge to. Then wind the solder around the cartridge in the counter-clockwise direction (looking with the pen tip facing you) until you are about 3/4" away from where the spring rests, then cut the solder.
(please note, I do not have any solder at the moment so I am using a reasonably similar wire to demonstrate)
STEP 5: Stop the Clip From Spinning
Hot glue the length of wood on the pen tube in a way that it will stop the clip from spinning as you click.
STEP 6: Assemble
Put the pen back together as you would have normally (make sure nothing is rubbing anything), but make sure the end of the solder can poke slightly through the hole you drilled. Take a bit of solder out of the hole.
You are done, and now if you click the pen, the ink cartridge should spin and it should feed about 5mm (correction, 2mm) of solder.
You can add another short pen tube with another metal tip to guide the solder.
26 Comments
gosh_d 17 years ago
PointyOintment 11 years ago
*Thinking about this again, I thought of a way a leadscrew pencil might be good for this:
1. Detach the knob from the leadscrew and attach it to a rod that runs down the center of the pencil (where the lead was).
2. Coil the solder around the rod.
3. Connect the solder to the rod so that it can slide along, but not turn around the rod. (A slot in the rod might work.)
4. Turn the knob.
It might be a bit less convenient to turn the knob than to press the button on top of a clicky pen/mechanical pencil.
PointyOintment 17 years ago
theRIAA 17 years ago
frank26080115 17 years ago
qualia 12 years ago
i know this is an oldish instructable so you've probably found your own solutions but i just found it and thought i'd share.
frank26080115 12 years ago
This Instructable is embarrassing compared to my recent projects
Anyways, your comment itself deserves to be its own Instructable!
qualia 12 years ago
i'll post it up at some point though.
maurice1993 12 years ago
Here, man, you see, I'm not from US or anything, so I do not know how do you call these, but it's fairly simple to use it, you just have to load if with solder, and in each click you'll have a bit of solder, as long the solder are the right size. I just lost mine so I can't give you a photo of that in the battlefield, but as long I buy one I'll send a pic for you to see...
AlexTheGreat 17 years ago
g0dl355 16 years ago
Aeshir 17 years ago
!Andrew_Modder! 16 years ago
sgt.paper 16 years ago
FreshPineSent 15 years ago
Father Christmas 15 years ago
Mr.Ownage 15 years ago
Kepp the good work coming!
