Clip Indicator (LED) for Any Power Amp
Intro: Clip Indicator (LED) for Any Power Amp
A power amplifier cannot deliver an output wave wider than its power supply voltage. When you reach the limit, increasing gain may sound louder but sound will be distorted and can even damage speakers .This simple clipping indicator circuit will announce with an LED that you have reached that limit.
STEP 1: Circuit Diagram & Main Components
Q1 BC547 NPN transistor
Q2 BC557 PNP transistor
D1-D3 1N4148 diode
note: If your amp V+ voltage is higher than 45v use BC546/BC556 (up to 65v) or other higher voltage ones.
also increase R4 for a led current of 30mA. ( R=v/a )
STEP 2: Q1: Emitter Follower
STEP 3: Q2: Led Driver
STEP 4: C1: Peak Hold
For longer "peak hold" time increase R3 up to 100K
50 Comments
TibiP2 1 year ago
nishantkundu18 3 years ago
jessejanssen94 3 years ago
I'm mostly interested in the way on how it'll be designed around different setups, if it's possible I guess this would give options to create very nice clipping interfaces for people with audio in their vehicle.
Best regards,
Jesse
bassblaster505 3 years ago
MatīssB4 3 years ago
someloser 7 years ago
Could I replace the x3 diodes with a single LED? As the circuit continuously drains several milliamps but putting a power indicator LED in there would put that current drain to good use especially when powered by a battery.
simpletronic 7 years ago
Hi! yes you can, but make sure the forward voltage (Vf) drop of the led is close to 2v. Lower Vf, and indicator wont light. Higher Vf, and the indicator will light prematurely.
in this chart you will find the typical Vf´s of different color leds.
Greetings & thanks!
Filippo1980 4 years ago
Oh that's handy then, a green LED will drop around 2.1v which is very close to the 2.2v I measured being dropped by the diodes.
livoto80 4 years ago
Alexander4269 4 years ago
BobzB1 5 years ago
codebeat 7 years ago
Nice tut. Just wondering, in the 80's some speaker cabinets (see photo on the right side) got a overload indicator, any idea's how these work?
Another one that got this feature, it is a passive speaker (like the other example), not an active one.
BobzB1 5 years ago
JustasK1 6 years ago
How to make amplifier limiter on relay, that turns off speaker then amplifier is overloading?
BobzB1 5 years ago
AndrewM491 6 years ago
Hi, nice work on your circuit design... few questions...
It would appear the LED is only lit while the output is clipping, if that is for fractions of a second then the led may not be visible... would i be correct to say adding a capacitor between the LED anode and the 0v rail will allow the led to stay lit while the capacitor discharges through the LED?
BobzB1 5 years ago
